if you have pbp3 then a config looks loke this
Code:#CONFIG __config _HS_OSC & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _BODEN & _CP_OFF & _CPD_OFF #ENDCONFIG
@ Device Pic16F630,HS_osc, wdt_off, pwrt_on,protect_off, mclr_off
looks wrong for any version
I just tried this command.
It is not recognised on my PBP 2.40
But I guess without this configuration line, setting the fuses in IC-Prog is also valid and sufficient?
"My" command was valid for my Pic16F84A.
