Replacing LCDOUT with direct statements?
Results 1 to 10 of 10
    OK
    Default Re: Replacing LCDOUT with direct statements?
    I did a project several years ago for a friend. Maybe this code can help you. This isn't the entire program, but close. I am updating only values that change, leaving the rest alone.
    '*  Date    : 8/13/2017                                         *
    '*  Version : 1.6                                               *
    '*  Notes   : PIC18F26K22                                       *
    RS      var     PORTC.6             ;Register Select for LCD, 0 = Comd, 1 = Data
    En      var     PORTC.7             ;Pulsout Enable to write to LCD
    b0      var     byte                ;Main For/Next Loop Variable
    b1      var     byte                ;LCDout Variable
    b3      var     byte                ;For/Next Loop Variable
    BatL    var     byte                ;Display Screen Position Number
    Batt    var     byte                ;Battery Voltage, ADC Steps
    BattA   var     byte[3]             ;Battery Voltage, ASCii Converted
    BatV    var     byte                ;Battery Voltage XX(.)X
    CFG     var     byte                ;Set-Up Bits, DATA @10
    Disp_Sel var    byte                ;Cursor Points To, 10 Choices in Disp_Prog
    DispSet var     CFG.3               ;Denotes Display Programming Complete
    IOL     var     byte                ;Display Screen Position Number
    Line1   var     byte[17]            ;Disp_Prog Line1 Display Data Variable
    Line2   var     byte[17]            ;Disp_Prog Line2 Display Data Variable
    Line3   var     byte[17]            ;Disp_Prog Line3 Display Data Variable
    Line4   var     byte[17]            ;Disp_Prog Line4 Display Data Variable
    LnSel   var     byte                ;Line Selected, 1 >> 4d
    LPsi    var     byte                ;Low Operating Pressure
    LPsiA   var     byte[2]             ;LPsi ASCii Converted
    Order   var     byte                ;Used in Disp: for positioning
    OrderCt var     byte                ;Disp_Prog Order Keeper for Variables Displayed, Line1
    Pos     var     byte                ;Display Screen Position Number
    Psi1    var     byte                ;Vaporizer Pressure, ADC Steps (8 bit)
    Psi1A   var     byte[2]             ;Vaporizer Pressure, ASCii Converted
    Psi1L   var     byte                ;Display Screen Position Number
    Psi1P   var     byte                ;Vaporizer Pressure, ADC >> Psi
    Psi2    var     byte                ;Regulated Pressure, ADC Steps (8 bit)
    Psi2A   var     byte[2]             ;Regulated Pressure, ASCii Converted
    Psi2L   var     byte                ;Display Screen Position Number
    Psi2P   var     byte                ;Regulated Pressure, ADC >> Psi
    PTarg   var     byte                ;Target Vaporizer Pressure, Psi
    PTargA  var     byte[2]             ;Target Vaporizer Pressure, ASCii Converted
    PTargL  var     byte                ;Display Screen Position Number
    Ppres   var     byte                ;Target Vaporizer Pressure, ADC >> Psi
    TPS     var     byte                ;TPS ADC Steps, Read/Display Only
    TPSA    var     byte[3]             ;TPS Volts, ASCii Converted
    TPSL    var     byte                ;Display Screen Position Number
    TPSV    var     word                ;TPS Volts, 0.00 >> 5.00
    VDCL    var     byte                ;Display Screen Position Number
    VTL     var     byte                ;Display Screen Position Number
    Work    var     byte                ;Source of Working Bits
    ;Program Labels:
    Init:
        Order = 0                       ;Display top of screen
        Work = 0                        ;Stock, Clears All Operating Bits
        LnSel = 1                       ;Line Selected for Display
        Source = 1                      ;Stock on Output to CNG ECU
        GP = 0
        Inj = 0
        Rled = 0
        gosub Load_Vars                 ;Loads EEPROM Values into Appropriate Variables
        goto Init_LCD                   ;Starts LCD, Loads Start Screens
      ;do stuff
        gosub Disp
        goto Main
    Init_LCD:
        low RS
        PORTB = $30
            high En
            pauseus 4
            low En
            pause 5
        PORTB = $30
            high En
            pauseus 4
            low En
            pauseus 160
        PORTB = $30
            high En
            pauseus 4
            low En
            pauseus 160
        PORTB = $38
            gosub Send
        PORTB = $10
            gosub Send
        PORTB = $0C
            gosub Send
        PORTB = $06
            gosub Send
        PORTB = 1
            gosub Send
            pause 1
        PORTB = $80
            gosub Send
        high RS
        pause 1
        for b0 = 0 to 15
            lookup b0, [" T-Cat Fuel Sys "], b1
            PORTB = b1
            gosub Send
        next b0
        low RS
        pause 1
        PORTB = $C0
            gosub Send
        high RS
        pause 1
        for b0 = 0 to 15
            lookup b0, ["   Controller   "], b1
            PORTB = b1
            gosub Send
        next b0
        low RS
        pause 1
        PORTB = $90
            gosub Send
        high RS
        pause 1
        for b0 = 0 to 15
            lookup b0, ["   R & D Club   "], b1
            PORTB = b1
            gosub Send
        next b0
        low RS
        pause 1
        PORTB = $D0
            gosub Send
        high RS
        pause 1
        for b0 = 0 to 15
            lookup b0, ["  Version 1.7   "], b1
            PORTB = b1
            gosub Send
        next b0
        for b0 = 1 to 5
            pause 250
            Rled = 1
            pause 250
            Rled = 0
        next b0
    Start_Screen:
        low RS
        PORTB = 1
            gosub Send
        PORTB = $80                         ;Line 1
            gosub Send
        high RS
        pause 1
        for b0 = 0 to 15
            lookup b0, [" To Switch, 1/0 "], b1
            PORTB = b1
            gosub Send
        next b0
        pause 1
        low RS
        PORTB = $C0                         ;Line 2
            gosub Send
        high RS
        pause 1
        for b0 = 0 to 15
            lookup b0, [" Display Val ^ "], b1
            PORTB = b1
            gosub Send
        next b0
        pause 1
        low RS
        PORTB = $90                         ;Line 3
            gosub Send
        high RS
        pause 1
        for b0 = 0 to 15
            lookup b0, ["  Program ^ & v  "], b1
            PORTB = b1
            gosub Send
        next b0
        low RS
        PORTB = $D0
            gosub Send
        high RS
        pause 1
        for b0 = 0 to 15
            lookup b0, ["T-Cat Controller"], b1
            PORTB = b1
            gosub Send
        next b0
    Start2:
        Source = 1
        do
        loop while (ButU = 0) and (ButT = 0) and (ButD = 0) and (Sw = 0)
        if Sw = 1 then
            pause 50
            if Sw = 1 then
                IO = 1
                do
                loop while SW = 1
    ;            Source = 0
                GP = 0
                Inj = 0
                Rled = 0
                PAUSE 200
                goto Main
        If (ButU = 1) or (ButD = 1) then
            pause 50
            if (ButU = 1) and (ButD = 0) then
                do
                loop while ButU = 1
                GP = 0
                Inj = 0
                Rled = 0
                PAUSE 200
                goto Park
            if (ButU = 1) and (ButD = 1) then
                do
                loop while (ButU = 1) and (ButD = 1)
                goto Prog0
        goto Start2
    Disp:
        LnSel = 1
        low RS
        PORTB = 1
            gosub Send
        PORTB = $80
            gosub Send
        high RS
        OrderCt = LnSel + Order
        gosub Disp_Seq
        LnSel = LnSel + 1
        low RS
        PORTB = $C0
        gosub Send
        high RS
        gosub Disp_Seq
        LnSel = LnSel + 1
        low RS
        PORTB = $90
        gosub Send
        high RS
        gosub Disp_Seq
        LnSel = LnSel + 1
        low RS
        PORTB = $D0
        gosub Send
        high RS
        gosub Disp_Seq
        LnSel = 1
    Disp_Seq:
        Select Case OrderCt
            case is = 1         : gosub Set_TC1L        ;Vap Temp
            case is = 2         : gosub Set_PSI1L       ;Vap PSI
            case is = 3         : gosub Set_PSI2L       ;Regulated PSI
            case is = 4         : gosub Set_PTargL      ;Vap PSI Targ
            case is = 5         : gosub Set_LPsiL       ;Low PSI Aux Enable
            case is = 6         : gosub Set_TPSL        ;TPS
            case is = 7         : gosub Set_BatL        ;Battery Volts
        end Select
    Set_LPsiL:
        ARRAYWRITE LPsiA, [#LPsi]
        for b0 = 0 to 13
            LOOKUP b0,["Low PSI Set = "],b1
            PORTB = b1
            gosub Send
        next b0
        if LPsi < 10 then
            LPsiA[1] = LPsiA[0]
            LPsiA[0] = " "
        PORTB = LPsiA[0]
            gosub Send
        PORTB = LPsiA[1]
            gosub Send
    Set_BatL:
        ARRAYWRITE BATTA, [#BatV]
        for b0 = 0 to 9
            LOOKUP b0,["Battery = "],b1
            PORTB = b1
            gosub Send
        next b0
        if BatV < 100 then
            BattA[2] = BattA[1]
            BattA[1] = BattA[0]
            BattA[0] = " "
        PORTB = BattA[0]
            gosub Send
        PORTB = BattA[1]
            gosub Send
        PORTB = "."
            gosub Send
        PORTB = BattA[2]
            gosub Send
        PORTB = " "
            gosub Send
        PORTB = "V"
            gosub Send
    Set_Psi1L:
        ARRAYWRITE PSI1A, [#Psi1P]
        for b0 = 0 to 9
            LOOKUP b0,["Vap Psi = "],b1
            PORTB = b1
            gosub Send
        next b0
        if PSI1P < 10 then
            PSI1A[1] = PSI1A[0]
            PSI1A[0] = " "
        PORTB = PSI1A[0]
            gosub Send
        PORTB = PSI1A[1]
            gosub Send
        for b0 = 0 to 3
            PORTB = " "
            gosub Send
        next b0
    Set_Psi2L:
        ARRAYWRITE Psi2A, [#Psi2P]
        for b0 = 0 to 9
            LOOKUP b0,["Reg Psi = "],b1
            PORTB = b1
            gosub Send
        next b0
        if PSI2P < 10 then
            PSI2A[1] = PSI2A[0]
            PSI2A[0] = " "
        PORTB = Psi2A[0]
            gosub Send
        PORTB = Psi2A[1]
            gosub Send
        for b0 = 0 to 3
            PORTB = " "
            gosub Send
        next b0
    Set_PTargL:
        ARRAYWRITE PTargA, [#PTarg]
        for b0 = 0 to 13
            LOOKUP b0,["Vap PsiTarg = "],b1
            PORTB = b1
            gosub Send
        next b0
        PORTB = PTargA[0]
            gosub Send
        PORTB = PTargA[1]
            gosub Send
    Set_TC1L:
        arraywrite TC1A, [#TC1F]
        for b0 = 0 to 10
            LOOKUP b0,["Vap Temp = "],b1
            PORTB = b1
            gosub Send
        next b0
        if TC1F < 100 then
            TC1A[2] = TC1A[1]
            TC1A[1] = TC1A[0]
            TC1A[0] = " "
        PORTB = TC1A[0]
            gosub Send
        PORTB = TC1A[1]
            gosub Send
        PORTB = TC1A[2]
            gosub Send
        PORTB = " "
            gosub Send
        PORTB = " "
            gosub Send
    Set_TPSL:
        ARRAYWRITE TPSA, [#TPSV]
        for b0 = 0 to 5
            LOOKUP b0,["TPS = "],b1
            PORTB = b1
            gosub Send
        next b0
        if TPSV < 100 then
            TPSA[2] = TPSA[1]
            TPSA[1] = TPSA[0]
            TPSA[0] = "0"
        if TPSV < 10 then
            TPSA[2] = TPSA[1]
            TPSA[1] = "0"
            TPSA[0] = "0"
        PORTB = TPSA[0]
            gosub Send
        PORTB = "."
            gosub Send
        PORTB = TPSA[1]
            gosub Send
        PORTB = TPSA[2]
            gosub Send
        for b0 = 0 to 5
            LOOKUP b0,[" Volts"],b1
            PORTB = b1
            gosub Send
        next b0
    Send:
        high En
        pauseus 8
        low En
        pause 1
    Line_Select:
        select Case LnSel
            case is = 1 : PORTB = $80
            case is = 2 : PORTB = $C0
            case is = 3 : PORTB = $90
            case is = 4 : PORTB = $D0
        end select
    Prog0:
        read 6,PTarg
    Prog0d:
        do
            loop while (ButU = 1) or (ButD = 1) or (ButT = 1)
        low RS
            pause 1
        PORTB = 1
            gosub Send
        PORTB = $80
            gosub Send
        pause 1
        high RS
            pause 1
        for b0 = 0 to 15
            LOOKUP b0,["Target Vap Pres "],b1
            PORTB = b1
            gosub Send
        next b0
        low RS
        pause 1
        PORTB = $C0
            gosub Send
        high RS
        pause 1
        for b0 = 0 to 3
            LOOKUP b0,["    "],b1
            PORTB = b1
            gosub Send
        next b0
        arraywrite PTargA, [#PTarg]
        if PTarg < 10 then
            PTargA[1] = PTargA[0]
            PTargA[0] = " "
        PORTB = PTargA[0]
            gosub Send
        PORTB = PTargA[1]
            gosub Send
        if ButU = 1 then
            PTarg = PTarg + 1
            goto Prog0d
        elseif ButD = 1 then
            PTarg = PTarg - 1
            goto Prog0d
        for b0 = 0 to 3
            LOOKUP b0,[" PSI"],b1
            PORTB = b1
            gosub Send
        next b0
        if ButU = 1 then
            PTarg = PTarg + 1
            pause 10
            goto Prog0d
            PTarg = PTarg - 1
            pause 10
            goto Prog0d
        do
        loop while (ButU = 0) and (ButD = 0) and (ButT = 0)
        if ButU = 1 then
            if (ButU = 1) and (ButD = 0) and (ButT = 0) then
                PTarg = PTarg + 1
                for b0 = 0 to 100
                    if ButU = 0 then
                        goto Prog0d
                    pause 10
                next b0
        if ButD = 1 then
            if (ButD = 1) and (ButU = 0) and (ButT = 0) then
                PTarg = PTarg - 1
                for b0 = 0 to 100
                    if ButD = 0 then
                        goto Prog0d
                    pause 10
                next b0
        if ButT = 1 then
            pause 250
            if ButT = 1 then
                do
                loop while ButT = 1
                write 6,PTarg
                goto Prog1
        if (ButU = 1) or (ButD = 1) then
            pause 250
                goto Start_Screen
        goto Prog0d
    Prog1:
        read 7,LPsi
    Prog1d:
        do
        low RS
            pause 1
        PORTB = 1
            gosub Send
        PORTB = $80
            gosub Send
        high RS
            pause 1
        for b0 = 0 to 15
            LOOKUP b0,[" Low Operating  "],b1
            PORTB = b1
            gosub Send
        next b0
        low RS
        pause 1
        PORTB = $C0
            gosub Send
        high RS
            pause 1
        for b0 = 0 to 15
            LOOKUP b0,["  Pressure =    "],b1
            PORTB = b1
            gosub Send
        next b0
        low RS
        pause 1
        PORTB = $90
            gosub Send
        high RS
        pause 1
        arraywrite LPsiA, [#LPsi]
        if LPsi < 10 then
            LPsiA[1] = LPsiA[0]
            LPsiA[0] = " "
        PORTB = LPsiA[0]
            gosub Send
        PORTB = LPsiA[1]
            gosub Send
        for b0 = 3 to 14
            LOOKUP b0,[" PSI        "],b1
            PORTB = b1
            gosub Send
        next b0
        if (ButU = 1) and (LPsi < 40) then
            LPsi = LPsi + 1
            goto Prog1d
        elseif (ButD = 1) and (LPsi > 5) then
            LPsi = LPsi - 1
            goto Prog1d
        elseif (LPsi > 40) or (LPsi < 5) then
            goto Prog1d
        do
        if ButU = 1 then
                if LPsi < 40 then
                    LPsi = LPsi + 1
                for b0 = 0 to 100
                    if ButU = 0 then
                        goto Prog1d
                    pause 10
                next b0
        if ButD = 1 then
            pause 200
                if LPsi > 10 then
                    LPsi = LPsi - 1
                for b0 = 0 to 100
                    if ButD = 0 then
                        goto Prog1d
                    pause 10
                next b0
        if ButT = 1 then
            pause 250
            if ButT = 1 then
                do
                loop while ButT = 1
                write 7,LPsi
                goto Start_Screen
            pause 250
                goto Start_Screen
        goto Prog1d
    Load_Vars:
        read 6,PTarg
        read 7,LPsi
        read 10,CFG
    Thanks!
    That looks promising!
  1. Replies: 2
    Last Post: - 2nd June 2021, 16:11
  2. Replacing pic16f627a from a 16f84(a)
    By PicNewbie in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 03:35
  3. Replacing existing pic
    By Freman in forum General
    Last Post: - 6th June 2008, 00:53
  4. 8bit LCDout vs 4bit LCDout
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 24th May 2006, 13:16
  5. replacing chips
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 25th February 2005, 19:01
