ok tubleweed ,
will try some add in commands for timer 1
hope you shine a light on the low priority ints problem
cheers
sheldon
ok tubleweed ,
cheers
sheldon
Hi guys
is there any further tests i can do to help solve the low priory ints problem on the q43 chip
cheers
sheldon
Not really that I can think of.
I thought I'd try and load it into MPLABX so I could debug it, but it's been so long since I've used it w/PBP I can't seem to get the two so I can build and debug in MPLABX.
Using MPLABX 5.35 w/ PBP 3.1.4, a simple blinky program builds ok with the commandline, but even though it builds in MPLABX it fails the MPLABX make process so it won't load it.
I don't remember what makes the two happy...
You need to travel back in time ten years , last known semi workable setup was with mplabx 2.35I don't remember what makes the two happy...
I don't need the editor to work or anything... just be able to compile and load it so I can debug, even at the asm level.
I thought that part still worked, but maybe I'll try treating it as an asm project and do it that way.
