I/O pins behaviour after a SLEEP command
Results 1 to 3 of 3
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Default I/O pins behaviour after a SLEEP command
    Hi everybody,
    I need to enter into a power reduced situation with a PIC 18LF26K22 connected to some peripherals (e.g. amplifiers).
    The solution at the PIC level is obvious with the SLEEP instruction.
    However I also need to shutdown the peripherals by activating their SHDN pin which is connected to a port of the PIC. Activating this shutdown is the last thnk the PIC will do before going to SLEEP.
    When the PIC has entered the SLEEP mode, will the state of the pin state remain stable as programmed and usable for maintaining the peripherals in the shutdown mode ? Or will the I/O PIC circuits force it to go to '0' or to '1' ?
    Thank you for your help
    MikeBZH
    Default Re: I/O pins behaviour after a SLEEP command
    The pin will stay at the last level.
    May 2009
    Hi Ionnis,
    Many thanks for your quick and accurate answer... as usual !
    Best regards
    MikeBZH
  1. Status after @ SLEEP Command
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 17th June 2011, 14:10
  2. Sleep Command
    By thye in forum mel PIC BASIC Pro
    Last Post: - 27th October 2007, 15:28
  3. Help with PBP 'SLEEP' command
    By dreadmaul in forum mel PIC BASIC Pro
    Last Post: - 18th November 2006, 07:40
  4. Using Sleep command
    By suded in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 04:16
  5. Sleep command with 18F1220
    Last Post: - 7th April 2005, 11:11
