Another attempt for I2C eeprom, this time - 25C256.
Results 1 to 21 of 21
    Default Re: Another attempt for I2C eeprom, this time - 25C256.
    No difference - already tried all combos like 159+160, 160+161 and so on....
    The 25C265 as mentioned in the title is a SPI EEPROM. That won't ever work with the I2C command.
    If, on the other hand, it's the 24C256 then the state of the A0-A2 pins will have an effect on the address. Anyway, looking at the 24C256 datasheet:
    In Byte Write mode the Master sends a START, followed
    by Slave address, two byte address and data to be written
    (Figure 6).
    And then your code:
    I2CWrite sda, scl, 160, x, [x]
    You're using the x-variable as the address (and data) but have it defined as a byte.
    With that said, I have not ever used I2C so I'm certainly no expert.
    Yes I made an error in tittle, chip is certainly 24C256.
  1. i2c non-eeprom examples?
    By justDIY in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2010, 18:07
  2. Using eeprom for the first time- Help please
    Last Post: - 12th October 2009, 03:16
  3. Help with i2C eeprom
    Last Post: - 17th March 2006, 00:33
  4. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 19:03
  5. I2C EEPROM Programming
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2005, 15:03
