1Wire serial EEPROM, DS28EC20 and similar, any experience?
Results 1 to 14 of 14
    Default Re: 1Wire serial EEPROM, DS28EC20 and similar, any experience?
    1) Are there any PIC chips with 4KB of EEPROM available?
    2) I tried, can't make it work.
    3) Also does not work.
    4) Running on PIC16F887, code is already tight
    5) No open source hardware/software in my projects ever
    6) Actually they do work fine.
    And regarding the DS28EC20, if you noted, topic reads "DS28EC20 and similar" This means, that in case of need, say, DS2505 can be used, which has 64k.
    maybe one day you could post a complete compliable example of what you have tried along with a sketch, schematic or photograph
    of how everything is connected instead of useless and inaccurate snippets and zippo data on how anything is really wired
    did you even try anything from this thread or am i completely wasting effort on you
    I don't know, haven't checked but I did not say EEPROM, I said FLASH. You can store things in the program memory, after all that's how the program is held in there right.
    Allright, post your code and we might be able to help.
    Use something slightly more modern then. 18F46K42 has 64k of FLASH and 4k of RAM, 18F47K42 doubles that again and they are both cheaper than the old 16F887.
    OK, yet you're scouring the forum for code to use - strange.
    Well, there you go - in that case use it.
    As far as I can see the DS2505 is 16kbit, not 64kbit. It can talk to the uC at 16.3kbit / second - that's insanely slow even compared to I2C (if speed doesn't matter then fine, no problem). And it's an "add-only" memory meaning you can program it over the 1-wire bus but one time only, there's no way to erase it.
    I'm getting 16F887 for about 30 cents Ones you mentioned cost 10-20 times more
    For the I2C/SPI EEPROM I already had separate topics open with code posted, but nothing happened
    And 1 wire has it's own advantages - it needs 1 wire to work My current project uses TQFP-44 PIC16F887
    and there is LCD screen, DS3231, TM1639, keypad, USB PD trigger and whole bunch of various hardware
    attached to it, so in search for available pins, I have to do tricky things, like using piezo buzzer for alarm, and combining
    that pin with LCD enable pin
    Similarily, I have no issues with OTP ROM - all it has to do is contain static text strings and font data - no need to update
    it ever
    Oh by the way, I've implemented famous Casio VL-1 "Da da da" beeper rhythm playback with PBP, after I polish the code, will post it for public
    OK
    it ever
    If you create Constant (CON) strings, you can store them categorically within a CALL/GOSUB routine. Using a Line variable (Line VAR BYTE) just set that to the text line needed.
    Line VAR BYTE
    Language VAR BYTE
    String VAR BYTE[16] 'String buffer to hold ASCII text
    Line = 1 'Welcome
    IF Language = 1 THEN 'English
     GOSUB Get_English
    ELSEIF Language = 2 THEN 'Spanish
     GOSUB Get_Spanish
    ELSEIF Language = 3 THEN 'German
     GOSUB Get_German
    Get_English:
     SELECT CASE Line
      CASE = 1 : String = "Welcome"
      CASE = 2 : String = "Select Language"
      CASE = 3 : String = ...etc
     END SELECT
    Get_Spanish:
     SELECT CASE Line
      CASE = 1 : String = "Bienvenidos"
      CASE = 2 : String = "sel idioma"
     END SELECT
    Get_German:
     SELECT CASE Line
      CASE = 1 : String = "Willkommen"
      CASE = 2 : String = "Sprache auswählen"
    This should give you the idea.
  1. Serial EEPROM
    By William in forum mel PIC BASIC Pro
    Last Post: - 10th July 2009, 19:09
  2. something similar to DEC command
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 00:24
  3. Problems with CRC8 Calc in 1Wire
    By JohnB in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 23:01
  4. what's similar to the 16f84a?
    By kenpo in forum General
    Last Post: - 18th February 2005, 19:26
  5. enumerate 1wire bus
    By justDIY in forum mel PIC BASIC Pro
    Last Post: - 30th June 2004, 20:19
