My code for ADC button handling, it works, but can it be slimmed down?
Results 1 to 28 of 28
    Default Re: My code for ADC button handling, it works, but can it be slimmed down?
    So at any given moment you will not know which button was hit and will have to scan again.
    But even so, a flag for each button pressed is needed to keep it from regarding it as new press.
    OK
    Regarding flags, here is a trick I use:
    ButtonA VAR WORD
     Button1 VAR ButtonA.0
     Button2 VAR ButtonA.1
     Button16 VAR ButtonA.15
    This creates bit flags. To use them:
    Button4 = PORTC.3
    If you have many inputs scattered around various ports and you want to "gather them" in one consecutive block so you can iterate over them using a loop then sure, why not. Otherwise I must say I don't see the point of doing that. You might as well simply alias the bit variable directly to the port bit/pin and be done (after all, the Port registers is just another byte in memory - right).
    Button4 VAR PortC.3
    You'll save RAM, FLASH and processor cycles by not first copying the value of one bit variable (PortC.3) to another (Button4) only to then evaluate the state of Button4 variable.
    But, I might be missing the point alltogether, in which case I apologise.
    /Henrik,
    Here there are not ports... Only a ADVAL from ADC since the buttons are read as analog voltage.
    its a fairly simple process , 10 bits per button is easy , 8 bits with a bit of effort
    providing the button check is called in a loop at a relatively consistent rate.
    the program structure matters , spaghetti code won't get good results
    sudo method
    b1cnt  var byte
    newb1  var bit
    b1dun  var bit
    b2cnt  var byte
    newb2  var bit
    b2dun  var bit
    osc=8
    t1con=$01;32mS
    main
    if pir1.0
    pir1.0=0
    gosub getkey
    if newb1 gosub dob1
    if newb2 gosub dob2
    getkey:
    read adc
     b1cnt = b1cnt<<1
     b2cnt = b2cnt<<1
    if adc in b1 range
      b1cnt = b1cnt+1
    elseif if adc in b2 range
      b2cnt = b2cnt+1
    if !b1dun
      if b1cnt=255 then newb1=1  ;32*8mS
      if b1cnt=0 then b1dun=0
    if !b2dun
       if b2cnt=255 then newb2=1
       if b2cnt=0 then b2dun=0
    dob1:
    b1dun=1
    newb1=0
    do b1 stuff
    dob2:
    b2dun=1
    newb1=0
    do b2 stuff
  1. Long / short press button...but reading ADC
    Last Post: - 10th July 2016, 08:37
  2. Replies: 42
    Last Post: - 18th March 2012, 23:02
  3. How come my DS18S20 code still works?
    By Wilson in forum mel PIC BASIC Pro
    Last Post: - 30th July 2011, 02:59
  4. 12 bit or higher ADC on a PIC that works with PBP?
    By Brandon in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 17:19
  5. ADC -how it works?, pic -
    By matias in forum mel PIC BASIC Pro
    Last Post: - 13th March 2007, 21:54
