My code for ADC button handling, it works, but can it be slimmed down?
Results 1 to 28 of 28
    Default My code for ADC button handling, it works, but can it be slimmed down?
    Hello,
    This is my code for handling two buttons connected to ADC input.
    It works fine, and what was most important, it prevents repeated key action -
    user has to release the button and press it again, to call needed action again.
    However, there are quite a lot of variables, and their number will double with
    more buttons being added.
    So maybe there is a way to make it simpler, while still maintaining
    "do not repeat action" functionality?
    menu: 'main loop for button handling
    adcin 1, adcval   'read keys
    if adcval=255 then n1=0: n2=0: left=0: right=0  'if no key, then reset both button variables
    if adcval<10 then left=left+1 'detect button presses
    if adcval>100 and adcval <130 then right=right+1 'detect button presses
    if left>100 and n1=0 then 'if button pressed enough and it was not pressed before
    left=0
    n1=1
    gosub action1 'button 1 tasks
    if right>100 and n2=0 then 'if button pressed enough and it was not pressed before
    right=0
    n2=1
    gosub action2 'button 2 tasks
    pause 1 'input delay
    goto menu
    OK
    Default Re: My code for ADC button handling, it works, but can it be slimmed down?
    SELECT CASE adcval
      CASE < 10 : left=left+1 'detect button presses
      CASE < 100
    @ NOP
      CASE < 130 : right=right+1 'detect button presses
    END SELECT
    You might try the SELECT CASE method of parsing through. The above snippet should give you an idea.[/FONT]
    Thanks!
    My main concern is number of variables needed...
    code snippets do not provide any where near the required info to provide a meaningful answer, not even one var definition is even provided
    for a meaningful answer
    1 how often is routine called
    2 is it called on a regular timed basis
    3 how responsive does it need to be
    the minimum key data necessary would be a count to detect a debounced press a bit to indicate a new press detected and a bit to indicate
    the press has been acknowledged and acted on provided the right conditions exist
    1. At least 10 times per second.
    2. Yes
    3. As responsive as any other device, where user presses key and expects immediate feedback.
    if right>100
    so button has to held for ten seconds till you get a response ?
    not in my book, i doubt the thing is working after 300mS
    2. Yes
    like how regular how often really
    No.
    I mean keyboard is polled at least 10 times per second.
    This is general interactive device control, with direct feedback
    like your TV remote.
    Why not use the genuine BUTTON command ?????????????????
    of course, needs some "brainwork" and practise - and of course at least " read that f...... manual " ... "
    but the result is worth the effort ...
    " Just my two cents " ...
    Read 1st post 1st
    This is ADC input.
    Read 1st post 1st
    This is ADC input.
    ADC for ONLY two buttons and " immediate response " ( sic ) ??? ...
    if it's your choice ... go on ! ( ) ...
    adc key reading is a good tried and tested technique and can be very responsive, the question here is can it be done
    using less memory. the answer is yes of course, if done in a methodical way.
    c1 has opted not to discuss or elaborate on his implementation in any meaningful way. end of story
    This is just an example for 2 buttons
    for 20 buttons there should be 40 variables
    I wanted to avoid that
    this is why I asked
    With 10 or 20 keys, how do you handle the event of more than one key being pressed at the same time?
    By clever selection of ADC resistors.
    This had been solved long time ago, and not by me
    OK
    Recent posts got me thinking. Are you designing something with a bunch of buttons, each with a specific functionality? Or are you trying to do something more akin to a key pad? If you're using a standard key pad there are set-ups using resistors to create a narrow voltage range with the press of any individual key. That only requires one analog input to read any key press.
    https://aws1.discourse-cdn.com/ardui...2_542x500.jpeg
    12 buttons is ok with 8 bit adc . with 16 the last row gets down to 2 or 3 counts separation , a bit close for comfort in my view
    At current stage, I'm looking for more efficient and small code
    for ADC key handling.
    Doesn't post#2 with the use of Select Case do what you want with the least code/var usage?
    No it does not.
    It does not do "do not repeat action until user releases and pushes key again"
    if !flag then
        SELECT CASE adcval
          CASE < 10 : left=left+1:flag=1 'detect button presses
          CASE < 100
        @ NOP
          CASE < 130 : right=right+1 :flag=1'detect button presses
        END SELECT
    Something like that then?
    Yes and we again will have extra "left" and "right" variables, one per each button - what I wanted to avoid
    maybe I am a bit slow.. But how you can have 40 buttons but not 40 variables to distinct between them?
    ADCIN X,ADVAL
    IF ADVAL=20 then Gosub Y1
    IF ADVAL=10 then GOSUB Y2
    IF ADVAL=30 then GOSUB Y3
    and so on.
    So at any given moment you will not know which button was hit and will have to scan again.
    But even so, a flag for each button pressed is needed to keep it from regarding it as new press.
    OK
    Regarding flags, here is a trick I use:
    ButtonA VAR WORD
     Button1 VAR ButtonA.0
     Button2 VAR ButtonA.1
     Button16 VAR ButtonA.15
    This creates bit flags. To use them:
    Button4 = PORTC.3
    If you have many inputs scattered around various ports and you want to "gather them" in one consecutive block so you can iterate over them using a loop then sure, why not. Otherwise I must say I don't see the point of doing that. You might as well simply alias the bit variable directly to the port bit/pin and be done (after all, the Port registers is just another byte in memory - right).
    Button4 VAR PortC.3
    You'll save RAM, FLASH and processor cycles by not first copying the value of one bit variable (PortC.3) to another (Button4) only to then evaluate the state of Button4 variable.
    But, I might be missing the point alltogether, in which case I apologise.
    /Henrik,
    Here there are not ports... Only a ADVAL from ADC since the buttons are read as analog voltage.
    its a fairly simple process , 10 bits per button is easy , 8 bits with a bit of effort
    providing the button check is called in a loop at a relatively consistent rate.
    the program structure matters , spaghetti code won't get good results
    sudo method
    b1cnt  var byte
    newb1  var bit
    b1dun  var bit
    b2cnt  var byte
    newb2  var bit
    b2dun  var bit
    osc=8
    t1con=$01;32mS
    main
    if pir1.0
    pir1.0=0
    gosub getkey
    if newb1 gosub dob1
    if newb2 gosub dob2
    getkey:
    read adc
     b1cnt = b1cnt<<1
     b2cnt = b2cnt<<1
    if adc in b1 range
      b1cnt = b1cnt+1
    elseif if adc in b2 range
      b2cnt = b2cnt+1
    if !b1dun
      if b1cnt=255 then newb1=1  ;32*8mS
      if b1cnt=0 then b1dun=0
    if !b2dun
       if b2cnt=255 then newb2=1
       if b2cnt=0 then b2dun=0
    dob1:
    b1dun=1
    newb1=0
    do b1 stuff
    dob2:
    b2dun=1
    newb1=0
    do b2 stuff
  1. Long / short press button...but reading ADC
    Last Post: - 10th July 2016, 09:37
  2. Replies: 42
    Last Post: - 19th March 2012, 00:02
  3. How come my DS18S20 code still works?
    By Wilson in forum mel PIC BASIC Pro
    Last Post: - 30th July 2011, 03:59
  4. 12 bit or higher ADC on a PIC that works with PBP?
    By Brandon in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 18:19
  5. ADC -how it works?, pic -
    By matias in forum mel PIC BASIC Pro
    Last Post: - 13th March 2007, 22:54
