"WAIT" modifier with multiple choices - how to?
Results 1 to 12 of 12
    SWITZERLAND (french speaking)
    Default "WAIT" modifier with multiple choices - how to?
    Hi There,
    I'm wondering if it is possible to "WAIT" for more than only one condition at the time in DEBUGIN/SERIN2.
    I usually write something like this:
    START:
    DEBUGIN 1000,START,[WAIT("first")]
    I'd like to wait for more than the word "first" but also for "second" and "third".
    But how?
    Roger
    Default Re: "WAIT" modifier with multiple choices - how to?
    Yes you can. But maybe you can give an example of what you want?
    My circuit has a serial data receiver; it "waits" for three different sets of characters (= commands) to perform different actions, one at the time.
    If "READ" is received, it will do this; if "WRITE" is received, it will do that and so for the third command, "COPY".
    Voilą how I imagine it should be working (this is obviously not the actual code, just the idea of what it should be doing):
    START:
    DEBUGIN 1000,START,[WAIT("READ" OR "WRITE" OR "COPY")]
    IF "READ" DO...
    IF "WRITE" DO...
    IF "COPY" DO...
    I need to "wait" for either incoming command but there's where I'm stuck in the DEBUGIN/SERIN2 timeout loop.
    Due to my lack of knowledge, I have to make my circuit currently doing only one thing...frustrating
    Roger
    OK
    My approach would be to just receive whatever comes in, then parse it later.
    + 1
    though life would be easier if
    "READ" became "*READ/n" ditto for the others {/n=chr 13
    buff var byte[5]
    DEBUGIN 1000,START,[WAIT("*" str buff\5\13]
    then see what you got
    Great! I'll give it a try.
    Thanks a lot
    Roger
  1. How to do the "SerIN" and "SerOut " for the usb ?
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2015, 02:01
  2. Replies: 0
    Last Post: - 14th November 2013, 03:32
  3. Replies: 3
    Last Post: - 15th October 2012, 08:06
  4. Multiple "AND"'s in select case?
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 1st January 2010, 19:10
  5. Replies: 1
    Last Post: - 16th February 2005, 20:05
