18F4550 Config settings
Results 1 to 6 of 6
    Default 18F4550 Config settings
    It's been over 5 hours trying to make a 4550 run on external clock signal at 4MHz at pin 13 and normally this clock will drive the PLL at 96MHz then /2 making the 48MHz system clock.
    Unfortunately it does not work.
    My configuration is this. Anyone spots my mistake please?
        CONFIG  PLLDIV = 1            ; Divide by 5 (20 MHz oscillator input)
        CONFIG  CPUDIV = OSC1_PLL2    ; [Primary Oscillator Src: /1][96 MHz PLL Src: /2]
        CONFIG  USBDIV = 2            ; USB clock source comes from the 96 MHz PLL divided by 2
        CONFIG  FOSC = ECPLLIO_EC     ; external clock, PLL enabled (HSPLL)
        CONFIG  PWRT = OFF            ; PWRT disabled
        CONFIG  BOR = ON              ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  BORV = 3              ; Minimum setting
        CONFIG  VREGEN = ON           ; USB voltage regulator enabled
        CONFIG  WDT = ON              ; WDT enabled
        CONFIG  WDTPS = 512           ; 1:512
        CONFIG  CCP2MX = ON           ; CCP2 input/output is multiplexed with RC1
        CONFIG  PBADEN = OFF          ; PORTB<4:0> pins are configured as digital I/O on Reset
        CONFIG  LPT1OSC = OFF         ; Timer1 configured for higher power operation
        CONFIG  MCLRE = ON            ; MCLR pin enabled; RE3 input pin disabled
        CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
        CONFIG  ICPRT = OFF           ; ICPORT disabled
        CONFIG  DEBUG = OFF           ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
        CONFIG  CP0 = OFF             ; Block 0 (000800-001FFFh) is not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (002000-003FFFh) is not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (004000-005FFFh) is not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (006000-007FFFh) is not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) is not code-protected
        CONFIG  CPD = OFF             ; Data EEPROM is not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-001FFFh) is not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (002000-003FFFh) is not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (004000-005FFFh) is not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (006000-007FFFh) is not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) are not write-protected
        CONFIG  WRTB = OFF            ; Boot block (000000-0007FFh) is not write-protected
        CONFIG  WRTD = OFF            ; Data EEPROM is not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot block (000000-0007FFh) is not protected from table reads executed in other blocks
    DEFINE OSC 48
    Default Re: 18F4550 Config settings
    to have clk out on osc2 pin mode cannot be any of the io modes ie ECPLLIO_EC needs to be ECPLL_EC
    clk out will be fosc/4
    ps
    time better spent knocking serial spam offenders like this on the head in my opinion
    http://www.picbasic.co.uk/forum/showthread.php?t=24436
    Thanks Richard.
    I really do not care if the clock will be available on clk2 out or not. I'd rather prefer to keep that pin as an I/O. But anyway. The thing won't run. Or at least at the expected speed.
    According to the PIC18F4550.INFO file, if I want to keep an I/O function on the clk2 pin, and also have PLL enabled the ECPLLIO_EC is to be used.
    I wonder if the order of configs play any role. I'll check it later today.
    p.s. I nailed the spammer!
    for 4m ext clock with usb and 48m fosc i/o on a6
      CONFIG  PLLDIV = 1         ; No prescale (4 MHz oscillator input drives PLL directly)
      CONFIG  FOSC = ECPLLIO_EC  ; EC oscillator, PLL enabled, port function on RA6 (ECPIO)
      CONFIG  FCMEN = OFF        ; Fail-Safe Clock Monitor disabled
      CONFIG  IESO = OFF         ; Oscillator Switchover mode disabled
      CONFIG  LVP = OFF          ; Single-Supply ICSP disabled
      CONFIG  XINST = OFF        ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    good work the spammers add no value
    This is the configuration that is making my life miserable...
    Cannot understand why on earth it does not work...
    Once it started at a very very low speed and that was it. Dead still since.
    At last it works!
    So embarrassed though... A bad connection was the problem on the breadboard. Duh!
    Thanks for the time you wasted with me.
  1. 12f629 config settings
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 23:39
  2. Config Settings for the 18 series
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 30th June 2009, 22:03
  3. PIC18F2685 config settings for 20 MHz
    By wwilson17 in forum mel PIC BASIC Pro
    Last Post: - 1st April 2008, 00:13
  4. Config settings
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 12th December 2007, 19:24
  5. 18F2550 - config settings
    Last Post: - 13th January 2007, 15:28
