I used it on win7, and if I remember correctly on XP. It should work on win10.
You have keys.PBP, with all defined keys, also in .doc document you have codes.
Also USBSERVICE should be called every 10mS or so. I wanted to implement it with DT INT, but newer did...
It should be something like this
This code is also from forum, but never tried it.Code:INCLUDE "DT_INTS-18.bas" INCLUDE "ReEnterPBP-18.bas" ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler USB_INT, _SERVICE_USB, ASM, yes endm INT_CREATE ; Creates the interrupt processor ENDASM USBINIT 'INITIALIZE USB USBSERVICE 'SERVICE USB UIE = $7F 'ENABLE USB INTERRUPTS UEIE = $9F 'ENABLE USB ERROR INTERRUPTS @ INT_ENABLE USB_INT SERVICE_USB: USBSERVICE @ INT_RETURN
