USB Keyboard
Results 1 to 20 of 20
Thread: USB Keyboard
    Default Re: USB Keyboard
    Oh, you naughty aerostar! I guess alzheimer is knocking my door...
    Too much info on this USB mess... Lost the links I kept in case I needed them back.
    Thanks people for the info.
    Henrik, if you find your test code, please do post it. Will save me some time I am sure.
    Sep 2009
    I made keyboard to use as shortcuts for EAGLE. Should be exactly what you need. I used it on easypic dev board. Pic should be 18F4550.
    Here is complete project My UsbKeyboard.zip
    I created that using many examples from forum...
    Thank you very much pedja089!
    Looks great and very close to what I need to do. have to add a small graphics display and test it on Win 10. Hope Win 10 do not pose any communication problem.
    Really appreciated.
    Sep 2009
    I used it on win7, and if I remember correctly on XP. It should work on win10.
    You have keys.PBP, with all defined keys, also in .doc document you have codes.
    Also USBSERVICE should be called every 10mS or so. I wanted to implement it with DT INT, but newer did...
    It should be something like this
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INT_LIST  macro		; IntSource,       Label,       Type,  ResetFlag?
            INT_Handler   USB_INT,  _SERVICE_USB,       ASM,  yes
        INT_CREATE		; Creates the interrupt processor
    USBINIT                'INITIALIZE USB
    USBSERVICE             'SERVICE USB
    UIE = $7F              'ENABLE USB INTERRUPTS
    UEIE = $9F             'ENABLE USB ERROR INTERRUPTS
    @ INT_ENABLE  USB_INT
    SERVICE_USB:
        USBSERVICE
    @ INT_RETURN
    This code is also from forum, but never tried it.
    Thanks for this tip also. I had in mind to make this Interrupt driven service but in a later stage.
    Thanks to your help I am making a progress after a lot of experimenting. Sure I do not understand the whole process but anyway...
    I managed to enumerate the PIC and display on an open text file a short string of characters from an 8 byte buffer.
    How can this buffer made bigger? I changed these in the main program
    USBBufferSizeTX con 16
    USBBufferSizeRX con 16
    USBBufferCount Var Byte
    USBBufferIn var byte[16]
    USBBufferOut Var Byte[16]
    but still sends only the half buffer.
    Then I changed in the hid_desc.bas file this line
    retlw	0x10		; This should be the size of the endpoint buffer
    from 0x08 to 0x10 but still no joy. I attach the descriptor file.
    Any idea?
    P.S. I also changed
    #define HID_INT_OUT_EP_SIZE 8
    in the descriptor file to 16 but still sends 8 byte buffer...
  1. PIC18F14K50 USB Keyboard firmware
    By ScumariTec in forum USB
    Last Post: - 27th January 2021, 10:29
  2. USB keyboard emulator
    By Toley00 in forum USB
    Last Post: - 23rd January 2012, 00:57
  3. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 00:04
  4. Replies: 17
    Last Post: - 13th June 2008, 21:33
  5. Replies: 3
    Last Post: - 10th April 2008, 10:02
