EEPROM Transfert with Serial Communicator
Results 1 to 5 of 5
    Simon Brodeur's Avatar
    Simon Brodeur Guest
    Default EEPROM Transfert with Serial Communicator
    I must transfert an entire 256K I2C EEPROM to my PC. I currently use Serial Communicator included with PicBasic. My PIC send 16bit value as ASCII characters. Since I use 16bit value, I should be limited to around 16000 value. Can a terminal support that large number of value? I ask you because at around the 3/4 of transfert, the Terminal freeze, while the PIC continue to send value...
    It was working well with 5000 value, but now I can't get my precious value to Excel because I record until the end of the EEPROM.
    I'm also trying to make a small terminal with VisualBasic, is it a good idea? Will I have the same problem. By this, maybe I could write directly the values to a file...
    Simon Brodeur
    mmm, interesting. What about if you do a pause sometimes to give some time to the PC to empty his buffer?
    Those programs i did with VB take a X amount of bytes, proceed them, send a message to the PIC to continue dumping, then rebegin.
    As now, no problem at all. Even if dumping MBs of Data.
    Simon Brodeur Guest
    Since I use the intrc oscillator, I'm limited to 2400 bauds. Between each value there's a 20ms of EEPROM reading. I'm sure that the computer can take that!
    well try RealTerm or maybe the crap windows Hyperterminal could also work
    Realterm => http://realterm.sourceforge.net/
    Have a look to the following link. It explain how to use RealTerm in Excel
    http://realterm.sourceforge.net/real...rom_excel.html
    Simon Brodeur Guest
    thank you for the site, it will be usefull. I'll try RealTerm...
    Simon Brodeur
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Replies: 5
    Last Post: - 29th January 2008, 10:19
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
