Pwm 16f628
Results 1 to 5 of 5
Thread: Pwm 16f628
    mladenovic's Avatar
    mladenovic Guest
    Default Pwm 16f628
    Hi
    I need help
    I have to read Port RB4 to RB7
    The number I get from that reading (0-15) it has to be PWM output.
    Mu question is how to use PWM on pic 16f628
    This PWM signal has to be active 300ms and then read again portb4 to portb7
    Rule
    1.read portb4 to portb7
    2.set pwm dutycycle (depend of reading value of portb)
    3.activate pwm for 300ms
    4.go to 1.
    Thanks Milan
    First there is no RB8, there is a RB7 though which is the 8th bit.
    Are you reading a DIP switch or something?
    I would read the port by using:
    pwm_value.0 = portb.4
    pwm_value.1 = portb.5
    pwm_value.2 = portb.6
    pwm_value.3 = portb.7
    This will load the value between 0-15 in the byte sized variable pwm_value. If your running @ 4 MHz then you could use:
    pwm portb.0,127,60
    This would give you a 50% duty cycle for about 300ms out on portb.0. Or you can use the hardware PWM which is on portb.3.
    mladenovic's Avatar
    mladenovic Guest
    Default Pwm
    Hi
    Thanks for help.
    Those 4 bits I get from PC parallel port.
    I would like to know how to use HPWM?
    Milan
    I think about the only thing you have to do is:
        hpwm 0,pwm_value,32767
        pause 300
        CCP1CON = 0
    The first line starts the PWM at whatever value is stored in the pwm_variable at 32.767kHz. It then pauses for 300ms then turns off the HPWM.
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  4. Using PWM built in Module 16F628
    Last Post: - 9th October 2007, 07:40
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
