How many times the loop turns for Darrel's "Kylon" LED chaser?
Results 1 to 7 of 7
    Default Re: How many times the loop turns for Darrel's "Kylon" LED chaser?
    Thanks! will give it a try - currently have no monitoring capabilities connected to the PIC. Only way to interact is to write data to EEPROM and check the value via pickit 3 standalone programmer. Will try to add write routine to your code...
    This circuit will be used to upgrade old Christmas tree decoration, shaped like a red star
    I had to gave up with that code, because on a larger physical size, discrete steps were quite visible.
    So I did another code instead, which works fine. Here's example.
    But I have a question. What if I use faster PIC, something from 18F series, running at 64mhz.
    Maybe it is possible to mod this code to have at least 10 bit resolution, instead of 8 ?
  1. how to "shift" a data into led matrix display ?
    Last Post: - 9th January 2015, 16:09
  2. Replies: 0
    Last Post: - 14th November 2013, 03:32
  3. Overflows "counter" in a loop
    Last Post: - 11th September 2010, 09:26
  4. Replies: 2
    Last Post: - 22nd January 2008, 14:25
  5. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 20:31
