How many times the loop turns for Darrel's "Kylon" LED chaser?
Results 1 to 7 of 7
    Default How many times the loop turns for Darrel's "Kylon" LED chaser?
    Hello.
    I want to use this code for my christmas light:
    http://www.picbasic.co.uk/forum/showthread.php?t=10564
    I've modified it for 5 leds and it works fine. However, I want it to not spin forever, but change some values, like speed and trails after several runs.
    All the magic is done via this code as I can guess:
    Main:    if LoopCount = TracerSpeed then             ; __[ Cylon/Kitt Scanner ]__      LoopCount = 0      BAM_DUTY(NextLED)=Brightness      if TraceDIR then                          ; if scanning left        NextLED = NextLED - 1        if NextLED = 0 then TraceDIR = 0      else                                      ; else scanning right        NextLED = NextLED + 1        if NextLED = BAM_COUNT-1 then TraceDIR = 1      endif    endif        FOR Idx = 0 to BAM_COUNT - 1                ; Drain all dutycycles       IF BAM_DUTY(Idx) > 0 then           BAM_DUTY(Idx)=BAM_DUTY(Idx)*DrainSpeed/(DrainSpeed+1)       ENDIF    NEXT Idx    pause Speed    LoopCount = LoopCount + 1GOTO Main
    It all works fine, besides that I can't find, how many times it loops for complete cycle? - I mean, single run from left to right and back, with all fades.Any ideas?
    Default Re: How many times the loop turns for Darrel's "Kylon" LED chaser?
    Copy-paste screwed up the code, here it is:
    Speed       CON 24        ; Smaller=Faster
    TracerSpeed CON 15        ; Smaller=Faster Left/Right
    Brightness  CON 255       ; Tracers DutyCycle
    DrainSpeed  CON 30        ; Smaller=Shorter Trail
    BAM_COUNT = 5
          LoopCount = 0
        NEXT Idx
        pause Speed
    GOTO Main
    OK
    To make it adjustable, change the CON values to VAR values. You will have to initialize them to some value (try starting with Daryl's CON values), then somewhere change them as you see fit. First play with different values in Daryl's code for the CONs and see how it affects the display. On a separate note, BAM_COUNT should have been Declared:
    BAM_COUNT VAR BYTE
    BAM_COUNT = 5
    The values of these settings in my example provide the effect I need.
    I just need to enclose that loop into FOR-NEXT, to be able to have control over it.
    And the issue is, I can't count, how many times loop turns around, to do single cycle (from left to right and back)
    OK
    Ok, try adding a few lines:
    Left/RightBrightness  CON 255       ; Tracers
    DutyCycleDrainSpeed  CON 30        ; Smaller=Shorter
    TrailBAM_COUNT = 5
    Cycle VAR BYTE  ;Count Full Cycles
          LoopCount = 0
            if NextLED = 0 then
            TraceDIR = 0
            Cycle = Cycle + 1
            IF Cycle = xx THEN
              Do Something
              Cycle = 0
            TraceDIR = 1
        NEXT Idx
          pause Speed
    GOTO Main
    This should increment your Cycle variable after a full left swing.
    Thanks! will give it a try - currently have no monitoring capabilities connected to the PIC. Only way to interact is to write data to EEPROM and check the value via pickit 3 standalone programmer. Will try to add write routine to your code...
    This circuit will be used to upgrade old Christmas tree decoration, shaped like a red star
  1. how to "shift" a data into led matrix display ?
    Last Post: - 9th January 2015, 17:09
  2. Replies: 0
    Last Post: - 14th November 2013, 04:32
  3. Overflows "counter" in a loop
    Last Post: - 11th September 2010, 10:26
  4. Replies: 2
    Last Post: - 22nd January 2008, 15:25
  5. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 21:31
