Once you figure out how an LED works, then you can skip any additional circuitry you have driving the MOSFET relay LED input, and just treat it like a normal LED.
All you need is a resistor in series with the input LED. According to the datasheet you want a min of 3mA to turn it on, so to be safe calculate R so that you get 5mA,
something like R=(5V-Vf)/0.005, where Vf is the LED forward voltage taken from the datasheet.
