Comparator Help reqd
Results 1 to 7 of 7
    G8RPI's Avatar
    G8RPI Guest
    The 16F630 divides down the Vdd for it's reference and the usable input range is about 0.3 to 3.5V with a 5V Vdd. the resoultion is about 0.15V (Vdd/32).
    Depending on your application, it may be worth considering the 16F676 with it's 10 bit ADC. The ADC allows you more freedom to add filtering etc in software.
    Robert G8RPI.
    Oct 2003
    Australia
    Hi Rob,
    At this stage, I'm just learing the basics (with a 16F628A), so I'm not ready to decide on a chip for that reason. (But thanks for the info)
    I have been able to get the comparator working using an external Vref by resistive divider network, and it works quite well. This I am ok with. (thanks to mister_e's simple code example).
    However, no luck when trying to use the internal voltage reference.
    I think this is my problem...
    The datasheet is not very clear when setting the VCON VR<3:0>: bits.
    For example, the datasheet states that the voltage reference specs should be
    3.0V < VDD < 5.5V
    But by following the formula for configuring the voltage reference I get values between:
    0 to 3.13V for VRR=1 and
    1.25 to 3.59V for VRR=0,
    assuming VDD=5V.
    Also, on another matter, if we want to output the internal Vref to RA2, (to monitor this voltage), should we set TRISA.2 to an output pin?
    Any Ideas?
    Oct 2003
    Australia
    Smile Solution Found!
    Ok,
    I have searched this forum and found a good link to Melanie's Comparator Tutorial. Fantastic, even for a dummy like me.
    http://list.picbasic.com/forum/messa...tml?1020960642
    Hope this helps anyone else out there.
    J
    Goodness... I didn't think that old thread was still in existance - let alone folks reading it!
