prog prob
Results 1 to 5 of 5
Thread: prog prob
    Just a thought...
    If you've blown the Configuration Fuse for CODE PROTECT you will read back all 0000's after programming. Run your PIC in a board... you may find it works as intended!
    Jun 2005
    Up the bush, Western Plains, NSW Au
    No, we didn't blow the code protect bit.
    The manufacturer seems to think it is a hardware problem, although I am not too sure, as I have done 12C508As, 16F84As, 16F877, 16F873 with no problems at all.
    So that is what you'll read if the CP bit was blown, 0000s huh? that's good to know.
    I think I chucked the few out that I had programmed, so I will do a fresh one tomorrow and see what transpires.
    Peter
  1. WRITE prob during power cycle 18f6722
    By jason in forum mel PIC BASIC Pro
    Last Post: - 24th May 2010, 22:06
  2. Replies: 3
    Last Post: - 26th April 2007, 20:02
  3. ic prog installation
    By sakthi in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 14:01
  4. is there a free prog that will
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 20th May 2006, 14:29
  5. Prob osc with PIC16f876 20 sp
    By kris in forum mel PIC BASIC Pro
    Last Post: - 15th March 2006, 12:19
