prog prob
Results 1 to 5 of 5
Thread: prog prob
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default prog prob
    Hi all, I am having a funny (strange, not ha ha) programming prob with some NEW but old stock 16C715 chips.
    I have a program, using only PORTB to drive an LCD. This works fine on a 'F84 but when I try to put it in a 'C715 nothing happens.
    I am using IC-PROG into an Australian MicroByte Development board that has not shown any problems with any other chips. I have tried some other "flash LED" type simple progs too BTW.
    When the "blown" chip is read, it comes up with either all 3FFF's (normal, new chip) or ALL 0000's. Absolutely nothing shows up as being programmed in.
    I HAVE read the spec sheet for the 'C715 but cannot decipher anything peculiar to these chips which would indicate some special features.
    IC-PROG has a 16C715 in its list of chips, so I would have assumed that it should be able to do all required to program them.
    I have seen some other programmers that DO NOT have the 'C715 in their list of chips, so does that indicate that there is something funny about these??
    Thank you all.
    Peter Moritz
    ADELAIDE Souith Australia.
    Wink programmer not programming the programmer's program
    Hi, Peter
    Is this a hardware or software problem ??? I noticed my PONYPROG soft doesn't like C series ...
    Jun 2005
    I did RTFM...
    anyway, I'm now onto the manufacturer of the developmenmt board, and he is intrigued too...We will follow up with him..
    Thanks Ace
    Just a thought...
    If you've blown the Configuration Fuse for CODE PROTECT you will read back all 0000's after programming. Run your PIC in a board... you may find it works as intended!
    Jun 2005
    No, we didn't blow the code protect bit.
    The manufacturer seems to think it is a hardware problem, although I am not too sure, as I have done 12C508As, 16F84As, 16F877, 16F873 with no problems at all.
    So that is what you'll read if the CP bit was blown, 0000s huh? that's good to know.
    I think I chucked the few out that I had programmed, so I will do a fresh one tomorrow and see what transpires.
    Peter
  1. WRITE prob during power cycle 18f6722
    By jason in forum mel PIC BASIC Pro
    Last Post: - 24th May 2010, 22:06
  2. Replies: 3
    Last Post: - 26th April 2007, 20:02
  3. ic prog installation
    By sakthi in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 14:01
  4. is there a free prog that will
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 20th May 2006, 14:29
  5. Prob osc with PIC16f876 20 sp
    By kris in forum mel PIC BASIC Pro
    Last Post: - 15th March 2006, 12:19
