Hello all,
I'm having an issue gettings the On Interrupt GoTo command to work.
I've tried the following:
DEFINE OSC 20
led var PORTA.2
INTCON2.6 = 1 ' Enable PORTB pullups
INTCON2.7 = 1
On Interrupt Goto myint ' Define interrupt handler
INTCON = $90 ' Enable INTE interrupt
loop: High led ' Turn LED on
Goto loop ' Do it forever
' Interrupt handler
Disable ' No interrupts past this point
myint: Low led ' If we get here, turn LED off
Pause 500 ' Wait .5 seconds
INTCON.1 = 0 ' Clear interrupt flag
Resume ' Return to main program
Enable
This is the PicBasic Pro example slightly modified for the PIC18.
It doesn't run the myint.
I've done other tests to where I monitor the value of INTCON on an LCD and the register IS getting triggered because INTCON.6 = 1 after I trigger the interrupt. Regardless tho, it doesn't execute the myint label.
Is there anything I'm doing wrong? Any specific config changes I need to get PBP to compile it correctly maybe?
Any help is greatly appreciated,
Philip
