Questions/Basic/16F628A
Results 1 to 11 of 11
    BertMan's Avatar
    BertMan Guest
    Excellent! There is a subroutine to convert 32bit floats to a usuable ascii format. Hmm.. I dont think the 628 will hold all that code.
    You could try using the 648, it has 4k.
    BertMan's Avatar
    BertMan Guest
    I ended up using a math co-mcu to do the conversions. This little 8 pin device can convert strings, floats, and longs using the spi interface and only cost me $14. Here is the link: http://www.sparkfun.com/shop/index.php?shop=1&cat=79. Its the umFPU v2.0. I think the cost justified the headaches of using microcode's floating routines, and you can convert a string to float in about 3 lines of code, so I can still use the 628...YEAH!!! Attached is an alpha version of code that I am waiting to test as soon as the device gets here. You can see floating and long conversions in the routines: FloatToString, ConvertSInt32, and SetConfigMenu.
    Conclusion to this thread: If you want an easy to use method for floating point conversion in the IEEE754 format, get a fp co-mcu.
