This is for the 452 but I think it should be pretty much the same thing.
Code:@ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H ' Oscillator Switchover Disabled ' Oscillator Type HS PLL @ __CONFIG _CONFIG2L, _BOR_ON_2L & _PWRT_ON_2L & _BORV_45_2L ' Brown-Out Reset Enabled ' Power-Up Timer Enabled ' Brown-Out Reset Voltage 4.5V @ __CONFIG _CONFIG2H, _WDT_ON_2H ' Watch Dog Timer Enabled @ __CONFIG _CONFIG4L, _STVR_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L ' Stack Over/Underflow Reset Enabled ' Low Voltage ICSP Programming Disabled ' Background Debugger Disabled
