LCD ports
Results 1 to 2 of 2
Thread: LCD ports
    electronicsuk's Avatar
    electronicsuk Guest
    Default LCD ports
    Hi all. I'm using a 16F877 with an LCD connected through a 4-bit bus to the upper 4 pins of port A.
    I have made a PCB for this circuit and only just realised that the ports I have chosen for the LCD might be a problem. Port A only has 6 bits, so I would need to define the LCD starting port as a.2, but PBP only allows you do define it as port 0 or 4. Is there any way around this without using assembly to write my own LCD routine?
    Thanks again.
    Matthew
    Not in PBP... change your circuit or write your own LCD routines.
    Melanie
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. LCD will not start
