Audio player
Results 1 to 14 of 14
Thread: Audio player
    Default Re: Audio player
    Jerson: Thanks for the info. The AT tiny is unbelievable!
    Mike: thanks for the link.
    We were doing this with an ISD5008. When that was discontinued we started moving into an ISD4003-08MPY. That was recently discontinued and are moving into an ISD17240. With a 4KHZ sampling frequency the 17240 will give you 8 minutes of record/playback.
    You mean ESP with in Arduino IDE, which needs good grasp of C, right?
    i do , never tried it but it looks straight forward
    https://github.com/earlephilhower/ESP8266Audio
    cannot see how you can get in between df player and sd card to decrypt a file, you need to drive your own dac or pay for a proprietary
    system that secures your audio data
    Bombay, India
    I just remembered. There are these series of chips from Aplus that do exactly what you want. They are available in various capacities and can be segmented. So, you could record a few segments and then play them in any order you want perhaps even chain them together. This one I have used APR48000 in the past.
    This thread might get you started http://www.picbasic.co.uk/forum/showthread.php?t=11369
    These search links might expand your horizons even more
    https://duckduckgo.com/?q=aplus+voic...nonical&ia=web
    Bombay, India
    The APR and ISD chips are basically meant for human voice and not high fidelity. They're inteded for TAM (answering machines) use.
    Hi Jerson.
    Thanks for the info. The Aplus and especially the aPR33A3 might be exactly what I need.
    Do they have distributer? Mouser or Arrow do not carry them.
    Also the idea of ESP32 that Richard posted is a good alternative. Thanks for that too.
    Bombay, India
    Hi Ioannis
    Not sure how you can order Aplus where you are. Perhaps you may need to buy direct from the manufacturer in Taiwan. I used to source mine locally from a distributor in tiny quantities.
    Best wishes
  1. WTV020-SD-20SS SD Card U Disk Audio Player Interface
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 4th March 2018, 04:48
  2. MP3 Player Using VS1011
    By lindomar in forum mel PIC BASIC Pro
    Last Post: - 28th October 2009, 20:26
  3. DVD Player Remote Control
    By koossa in forum Off Topic
    Last Post: - 1st January 2009, 11:35
  4. Build your own CD player for under $20
    By T.Jackson in forum Off Topic
    Last Post: - 12th November 2007, 15:27
  5. is there cd player code in picbasic
    By mech in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 20:43
