thanks a lot
Theese calculations will overflow when adc_in is greater than 655.
For 0-300 lbs output = adc_in * 100 / 341
For 0-400 lbs output = adc_in * 100 / 256
It would be better to use the "*/" operator for these calculations.
For 0-300 lbs output = adc_in */ 75
For 0-400 lbs output = adc_in */ 100
If you want proper rounding of the result you can use.....
For 0-300 lbs output = ((adc_in */ 750)+5)/10
For 0-400 lbs output = ((adc_in */ 1000)+5)/10
Oops, missed that one. I personally would use this:
d = 100
dummy = adc_in * d
adc_value = DIV32 256
Substitute 341 for the 256 is using the 0-300 lbs scale. The adc_value variable will contain the lbs.
thanks a lot guys
but more probelms occured...
after testing the program and testing the voltage received using a multimeter
the actually voltage range is approx 0.44 volts +/- .009 volts and the max load we were able to obtain is approx 4.99 volts +/- .009 volts.
can you please explain to me how the equations so i can understand the analog to digital conversion + plus can if possible, derive a new equation to fix this problem.
here's the source code:
Define LOADER_USED 1
Define LCD_DREG PORTB
Define LCD_DBIT 4
Define LCD_RSREG PORTB
Define LCD_RSBIT 0
Define LCD_EREG PORTB
Define LCD_EBIT 1
DEFINE OSC 4 ' Set Xtal Frequency
DEFINE ADC_BITS 10 ' Set resolution of conversion
DEFINE ADC_CLOCK 8 ' Set clock source (x/FOSC or FRC)
DEFINE ADC_SAMPLEUS 50 ' Set sampling time (in uS)
' INTCON.7 = 0 ' Enable PORTB pullups
' ADCON1 = 7 ' Make PORTA and PORTE digital
Low PORTB.2 ' LCD R/W low (write)
TRISA = %11111111 ' Set PORTA to all input
ADCON1 = %10000010 ' Set PORTA analog and right justify result
d VAR word
dummy var word
adc_in var word
W VAR WORD
adc_value var word
ADFM var ADCON1.7 ' ADC result format select bit
PCFG3 var ADCON1.3 ' ADC port configuration bit
PCFG2 var ADCON1.2 ' ADC port configuration bit
PCFG1 var ADCON1.1 ' ADC port configuration bit
PCFG0 var ADCON1.0 ' ADC port configuration bit
PCFG0 = 0 ' Configure AN0 as analogue input, others digital
PCFG1 = 1
PCFG2 = 1
PCFG3 = 1
ADFM = 1 ' Right justified result in ADRESL and ADRESH
loop:
adcin 0,adc_in ' Place the conversion of channel0 into adc_in
d = 100
dummy = adc_in * d
W = adc_value
Lcdout $FE, 1
Lcdout $FE, $80, #W," lbs"
goto loop
anymore help would be appreciated
thanks a lot
Ok, here's one way to do it.
The general formula would be ....
result = (adc_in - CalLO)*Range/(CalHI-CalLO)
.... where
adc_in = input from ADconverter
Range = Maximum load
CalLO = adc_in when load is zero
CalHI = adc_in when load is "Range"
You could calculate and "hardcode" the last two, but the best solution would be to make a small calibrationroutine that gathers the readings. I'll use 0.44v as zero load and 4.99v at maximum load(300lbs).
If you want rounding you could do .....Code:Range CON 300 adc_in VAR WORD CalLO VAR WORD CalHI VAR WORD div_val VAR WORD result VAR WORD dummy VAR WORD CalLO = 90 ' calculated calibrationvalue (0.44/5*1024) CalHI = 1022 ' calculated calibrationvalue (4.99/5*1024) div_val = CalHI - CalLO dummy = (adc_in - CalLO) * Range result = DIV32 div_val
/IngvarCode:Range CON 3000 adc_in VAR WORD CalLO VAR WORD CalHI VAR WORD div_val VAR WORD result VAR WORD dummy VAR WORD CalLO = 90 ' calculated calibrationvalue (0.44/5*1024) CalHI = 1022 ' calculated calibrationvalue (4.99/5*1024) div_val = CalHI - CalLO dummy = (adc_in - CalLO) * Range result = DIV32 div_val result = (result + 5) / 10 'rounded result
Thanks a lot Ingvar
You are the best
I'll try that code out
