How to do bitwise shift across several variables/array members?
Results 1 to 8 of 8
    Default Re: How to do bitwise shift across several variables/array members?
    I'm thinking it in the following way (as example, 2 byte array, shifted to right)
    1. Read both array bytes into variables A and B
    2. Shift B right 1 bit
    3. Add LSB from A as MSB to B
    4. Shift A right
    5. Write A and B back to array
    Repeat as desired.
    Correct?
    Aug 2011
    Yes, assuming you really do want a shift and don't want to rotate the value shifted out of B back into the MSB of the array.
    There's no need to copy the array bytes to A and B, but if it helps you keep it straight then go for it.
  1. SWAP COMMAND extended to Longs and array variables
    By longpole001 in forum PBP Wish List
    Last Post: - 9th April 2018, 23:41
  2. MIBAM and Array Variables in FOR-NEXT Loops
    By Homerclese in forum mel PIC BASIC Pro
    Last Post: - 25th August 2010, 12:50
  3. Seeting array variables in For-Next loop
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 07:01
  4. Reading Array values into variables
    Last Post: - 21st March 2005, 10:30
  5. List of Members
    By NavMicroSystems in forum Forum Requests
    Last Post: - 17th January 2005, 17:10
