How to do bitwise shift across several variables/array members?
Results 1 to 8 of 8
    Default How to do bitwise shift across several variables/array members?
    Say there is an array, having 16 member, 1 byte each. I want to shift bits say to right in that way, that the byte that "leaves" say 1st member, gets shifted in into 2nd member, and so on (and bit shifted out from last member, shifts into 1st member). Are there any simple ways to do this, except that reading each member bit by bit, assembling in new variable and writing back?
    Default Re: How to do bitwise shift across several variables/array members?
    So you want to say, I can shift left or right whole contents of an array?
    Are you using the shiftout command? If so you can select MSB or LSB first.
    No, there is no "one command way" to shift or rotate bits spanning multiple members of an an array. You will have to write some code to do that.
    OK
    Start with the least significant byte, use the Shift-Left "<<", then check the STATUS Register Carry bit to see if you have to add one to the more significant byte after shifting.
  1. SWAP COMMAND extended to Longs and array variables
    By longpole001 in forum PBP Wish List
    Last Post: - 9th April 2018, 23:41
  2. MIBAM and Array Variables in FOR-NEXT Loops
    By Homerclese in forum mel PIC BASIC Pro
    Last Post: - 25th August 2010, 12:50
  3. Seeting array variables in For-Next loop
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 07:01
  4. Reading Array values into variables
    Last Post: - 21st March 2005, 10:30
  5. List of Members
    By NavMicroSystems in forum Forum Requests
    Last Post: - 17th January 2005, 17:10
