First thought is that you need a generic Buffer sized to the length you want to send. For example:
I use the ARRAYWRITE command for what I think you're asking. Here is a piece of code that fills in blanks to my Buffer and loads them for a UART send:Code:LCD_Buffer VAR BYTE[18]
Code:Send_Vac: ;Send Current Vacuum Reading to Nextion tVac = Vac ;Create a Temporary Variable We Can Modify ARRAYWRITE NexBuf, ["vac.val="] ;Start Nextion Command Sequence, Occupies NexBuf[0] >> [7] IF tVac > 100 THEN ;If 3 Digits b0 = tVac / 100 ; Get the Xxx Value NexBuf[8] = b0 + $30 ; Convert it to ASCii tVac = tVac - (b0 * 100) ; Subtract the Xxx Value from tVac IF tVac < 10 THEN ;If xXx = 0 NexBuf[9] = $30 ;If tVac < 10, it's Zero (ASCii) ENDIF ;IF tVac < 10 ELSE ;tVac < 100 NexBuf[8] = $30 ;If tVac < 100, 1st Digit is Zero (ASCii) ENDIF ;IF tVac > 100 IF tVac > 10 THEN ;If Now Double Digit b0 = tVac / 10 ;Get the xXx Value NexBuf[9] = b0 + $30 ;Convert it to ASCii tVac = tVac - (b0 * 10) ;Subtract the xXx Value from tVac ELSE ;tVac < 10 NexBuf[9] = $30 ;If tVac < 10, it's Zero (ASCii) ENDIF ;IF tVac > 10 NexBuf[10] = tVac + $30 ;Convert xxX to ASCii & Write to Buffer FOR b0 = 11 TO 13 ;Generate "End of Message" Sequence: $FF, $FF, $FF NexBuf[b0] = $FF ;Load it to Buffer NEXT b0 ;FOR b0 = 11 TO 13 NexBuf[14] = 0 ;Tells Us To Turn UART TX INT Off RotX = 0 ;NexFlags.RotX -- Clear RotX Flag GOTO Start_TX ;No RETURN Needed, Using GOTO Command
