Several months ago, I purchased a PICkit 4 programmer/debugger pod inasmuch as support for the PICkit 3 pod has been discontinued. I wanted to create a programmer profile for the PICkit 4 in the Microcode Studio "View / Compile and Program Options / Programmer Options" so that "Compile Program" would open the PIC programming CMD window and program the target.
Similar to the the PICkit 3 profile I specified the following:
Name of new Programmer: PICkit4
Programmer Executable: ipecmd.exe
File Location: c:\Program Files (x86)\microchip\mplabx\v5.30\mplab_platform\mplab_ ipe
Select Parameters: -TPPK4 -P$target-device$ -F$hex-filename$ -E -M -Y -OL -OB
or
-TSBURxxxxxxxxx -P$target-device$ -F$hex-filename$ -E -M -Y -OL -OB
(TSBURxxxxxxxxx is the PICkit 4's serial number)
(The parameter definitions can be found in the "Readme for IPECMD.htm" document in the directory ..\v5.30\docs)
I discovered that the PICkit 4 doesn't release the PIC's reset line automatically at the end of the programming sequence, as the PICkit 3 does. One of three solutions work:
(1) disconnect PICkit 4's USB or target cable (the most obvious)
(2) close the batch programming CMD window using "q" (closing the CMD window with the upper r/h corner "X" won't release the reset)
(3) delete the "-OB" operator in the Parameter line, leaving -OL intact (this closes the CMD window automatically and releases the reset)
The "q" option works the best for me as it leaves the CMD window open for inspection in the event of a programming problem
