Loop issues
Results 1 to 19 of 19
Thread: Loop issues
    Feb 2004
    Michigan, USA
    Default Re: Loop issues
    Wow Richard, thanks for that! I guess I was way off. I used Melanie's Olympic Timer as the basis for my code and she included some of the things that you have advised against such as adding the SetTimer subroutine call in the Starttimer routine and INTCON.7=1.
    I tried your code and needed to change a few things.
    OSCCON = 110011
    TRISA = 111000
    TRISB = 010011
    became
    OSCCON = %01110011
    TRISA = %11111000
    TRISB = %00010011
    in order to compile.
    If you open the lid while its running and close it again, then push the start button, it doesn't turn on the outputs and start timing again. It does jump back to main, it will jump in to main1 and put the red led on solid, but doesn't run main1.
    If the switch is in the 60 second run position it runs for about 10 seconds - which I saw you had runtime = 10 so I changed that.
    In the 90 second position it runs for 90 seconds - perfect.
    In the 120 second position it ends almost instantly. I noticed this would happen sometimes in my code too. 100 and less and it works each time. I don't know what this phenomena is.
  1. Do Loop
    By skybox in forum mel PIC BASIC Pro
    Last Post: - 27th December 2012, 01:45
  2. Issues with a feedback loop.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 11th June 2012, 19:54
  3. if ... then loop
    Last Post: - 10th November 2010, 00:08
  4. Help with loop
    By wildbilly in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2007, 17:59
  5. While LOOP
    By actionplus in forum mel PIC BASIC Pro
    Last Post: - 5th March 2004, 15:59
