Strange Contactor Problem
Results 1 to 4 of 4
    Jun 2007
    Mansfield, UK
    Default Strange Contactor Problem
    Hi, I've built 3 cabinets, each has a relay with a 12V coil that switches 230V which feeds into the coil of a contactor.
    In one of the cabinets, the relay still works but the contactor has suddenly stopped energizing.
    What's strange is that if I push on the contactor (while the relay is on) then it energizes and if I push lightly then it switches rapidly on and off.
    It looks like there may be a loose wire to the coil within the contactor itself or maybe the coil has a break in it. I've checked the cabinet wiring and confirmed that's not the cause.
    All of these contactors are fairly new and have only been energized for around 24 hours total so I wouldn't expect a fault to develop so quick.
    Has anyone seen anything like this before?
    Is it possible I just got a faulty one?
    Should I be worried about the others breaking?
    These are the ones I bought https://www.amazon.co.uk/gp/product/B07GXM2Q3S/
    Is it worth replacing all 3 with more expensive ones or is this likely a rare occurrence?
    OK
    Default Re: Strange Contactor Problem
    It seems the quality of practically everything is deteriorating. Try a different relay and see if the problem goes away.
    Jun 2007
    Mansfield, UK
    It's definitely not the relay. I measured voltage across the contactor coil terminals so the relay was doing it's job.
    I had a spare contactor so I've been out today and replaced it then taken the broken one apart.
    The coil has a thin bit of springy metal sticking out either side of it. The top of the housing has 2 screw terminals and when pushed into place, the springy metal touches the bottom of the terminals.
    It looks like 1 of them wasn't quite springy enough and wasn't making proper contact.
    I'd guess that more expensive contactors would have better build quality but I wonder if they would still use the same sort of springy metal technique.
    I'm relived the coil hasn't completely burned out anyway. It's looking like it may just be a 1 off problem but I'll keep testing them and see if I have any more failures.
    Never trust brands not well known. Especially on marketplaces like Amazon, Ebay, Ali... etc.
    I only buy from a reputable reseller, distributor or directly from manufacturer when available.
  1. AC220v contactor fluctuates temperature.
    By amodpathak in forum mel PIC BASIC Pro
    Last Post: - 1st December 2014, 00:46
  2. A strange problem
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 25th January 2012, 21:08
  3. Very strange problem...
    By alanmcf in forum mel PIC BASIC Pro
    Last Post: - 7th May 2011, 06:28
  4. strange serout2 problem
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 7th January 2010, 09:33
  5. strange problem 12f675
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 13:47
