How exactly LCDOUT statement works?
Results 1 to 33 of 33
    Default Re: How exactly LCDOUT statement works?
    How to send $FE with LCDOUT ?
    X=$FE
    LCDOUT X
    It sends statements instead of byte data Found this accidentally - one of my custom font letters contained $FE pixels, and when using that char, it blowed up all my code. Took me several days to figure the reason (I was thinking about faulty EEPROM, display controller, SRAM on PIC and so on)
    Any ideas?
    This is very annoying and trashes whole idea of using LCDOUT statement...
    At the very beginning of this thread we went over how LCDOUT works, how it determines if what you give it should be sent as data or as commands, ie the $FE prefix. Now, a couple of weeks later you claim to have found this by accident and all of a sudden the LCDOUT command is at fault and doesn't work.
    LCDOUT works perfectly fine for its intended purposes. You're trying to use it for something it was not designed for and because that doesn't work the way you'd like the command is flawed, is that correct?
    Apart from editing the custom characters to not include $FE and/or writing your own routines to drive the display I don't have any ideas.
    Well, I have shifted letters to right edge, instead of left, and for text it indeed works, but when there is need to display the graphics...
    I'm using LCDOUT due it's simplicity and low memory use.
    The code below occupies less than 1k of memory (font data stored in eeprom), and allows you to have 4 lines X 18 characters text display with all custom letters on graphical display.
    C=0 '0=1st line, 8=2nd line, 16=3rd line and 24=4th line
    arraywrite topline, ["place text here   "]
    GOSUB GCODER
    stop
    GCODER:
    FOR X=0 TO 17 step 2	'READ ARRAY INTO VARIABLE, ARRAY MEMBER CHAR=EEPROM OFFSET
    Y=(topline[x]-65)*8
    Z=(topline[x+1]-65)*8 'READ  INTO VARIABLE AS TWINS
    FOR I=0 TO 7	'HELPER LOOP FOR CHARACTER READING
    READ Y+I,A 'READ EEPROM BYTES INTO VAR
    READ Z+I,B
    LCDOUT $FE,$80+i+c 'UPDATE Y POSITION
    LCDOUT $FE,$80+x/2 'UPDATE X POSITION
    if topline[x]=32 then a=0
    if topline[x+1]=32 then b=0 'blanker
    LCDOUT a
    LCDOUT b 'WRITE TO SCREEN
    'pause 10
    NEXT I
    NEXT X
  1. DS3231 works in one config, but does not works with other IC.
    Last Post: - 3rd December 2019, 19:52
  2. Alternate If-Then Statement Help
    By pdegior in forum mel PIC BASIC Pro
    Last Post: - 16th August 2007, 00:07
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 18:05
  4. 8bit LCDout vs 4bit LCDout
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 24th May 2006, 12:16
  5. A simple IF Statement!!!!
    By mslaney in forum mel PIC BASIC Pro
    Last Post: - 17th February 2005, 20:58
