How exactly LCDOUT statement works?
Results 1 to 33 of 33
    Default Re: How exactly LCDOUT statement works?
    As far as I know (correct me if I'm wrong) Arduinos support for NeoPixels is not part of the Arduino language itself. It's an add-in library that you have to download, install and include into your code in order to use it. It's not written or maintained by "Arduino the company" but by some third party (user, company, community) and I'm pretty sure there's more than ONE version of that library to choose from as well. Which can be confusing.
    The same thing goes for a lot of other stuff that "Arduino has" - it's libraries written by users and rest assured that the quality of them varies. Pretty much the same thing as "our" stuff.
    The big advantage is the encapsulation that proper function calls with parameter passing, local variables and return values provides. This provides the means to "hide away" even more stuff from the user than with PBP that doesn't support function calls and/or local variables. It's not magic though.
    A month or so ago I posted code for driving SK6812 RGBW LEDs. Using that particular code your example
    NEOPIXEL $ADDR,$BRIGHTNESS,$R,$G,$B
    Would look like:
    Red[ADDR]=R : Green[ADDR]=G : Blue[ADDR]=B : GOSUB UpdateDisplay
    And if you wanted you could rename the UpdateDisplay subroutine to NEOPIXEL and it would be
    Red[ADDR]=R : Green[ADDR]=G : Blue[ADDR]=B : GOSUB NEOPIXEL
    Not THAT much different now, is it? Granted, the "library" IS hardcoded to run at 64MHz so you won't run a 16x16pixel array on a 12F508 - for multiple reasons.
    You still need to include the code and set up some variables and aliases, but you don't get away from that with Arduino either.
    Regarding this particular library, it is supported and maintained by adafruit - major arduino contributor.
    To use it in your project, you just go to library manager, type in neopixel there, click download & install and that's all.
    all "define"s for it are here:
    #define LED_PIN 14
    #define NR_OF_PIXELS 12
    void setup() {
    strip.begin();
    strip.show(); // Initialize all pixels to 'off'
    And to use it:
    strip.setBrightness(255);
    strip.setPixelColor(1,10,30,40);
    no "hard coding" no "tied to 64mhz oscillator" - it just runs.
    I understand that from approach of older guys like myself
    this might appear to be not serious, but it allows you to get
    to the end result faster - you need neopixel led, you got it
    no need to care about osc clocks, tight timing and which
    chip can do it, and which - can't.
    Of course, arduino has it's own limitations - huge board with external osc
    you can't run it off tiny SOIC-8 chip, as you can do with PBP
    and that dreadful programming language, not meant to be understood by normal human beings
  1. DS3231 works in one config, but does not works with other IC.
    Last Post: - 3rd December 2019, 19:52
  2. Alternate If-Then Statement Help
    By pdegior in forum mel PIC BASIC Pro
    Last Post: - 16th August 2007, 00:07
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 18:05
  4. 8bit LCDout vs 4bit LCDout
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 24th May 2006, 12:16
  5. A simple IF Statement!!!!
    By mslaney in forum mel PIC BASIC Pro
    Last Post: - 17th February 2005, 20:58
