Arraywrite converts all letters to uppercase?
Results 1 to 11 of 11
    Default Arraywrite converts all letters to uppercase?
    Hello.
    topline	var byte [6]
    arraywrite topline, ["ABCabc"]
    FOR X=0 TO 6
    LCDOUT $FE, $01, DEC topline[x]
    next
    Outputs same codes for abc as for ABC. Seems like characters are converted to uppercase?
    Any ways to fix this?
    Default Re: Arraywrite converts all letters to uppercase?
    What device are you running this on?
    Here it works fine (18F57Q43)
    Start:
        HSEROUT["Start", 10,13]
        FOR X=0 TO 6
            HSEROUT [DEC topline[x],10,13]
        next
    Outputs:
    Start
    65
    66
    67
    97
    98
    99
    23
    With the 23 at the end being because you're reading past the last character written to the array.
    Pic16f886.
    I don't have that chip handy but I did compile the code for it and looked at the .lst file. Needless to say I can't see anything strange
    movlw   low (low (_topline))
    movwf   R5
    clrf    (R5) + 1
    movlw   041h
    clrf    PCLATH
    call    ARRAYWRITE
    movlw   042h
    clrf    PCLATH
    call    ARRAYWRITE
    movlw   043h
    clrf    PCLATH
    call    ARRAYWRITE
    movlw   061h
    clrf    PCLATH
    call    ARRAYWRITE
    movlw   062h
    clrf    PCLATH
    call    ARRAYWRITE
    movlw   063h
    clrf    PCLATH
    call    ARRAYWRITE
    As you can see it loads 41,42,43,61,62,63 (hex) so no conversion done. Not there at least.
    OK
    How are you checking the output? Is that what's displayed on an LCD? Maybe the issue is with the LCD. If you have a scope with comm protocol, verify the output from the PIC.
    I deleted all the code and defines
    did everything from blank sheet, and now it works properly....
  1. How to Debugin 2 letters and store in microcontroller memory?
    By Jananitharan in forum mel PIC BASIC
    Last Post: - 7th April 2011, 02:41
  2. Is there a better way to do this?... strings of letters
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 25th March 2011, 14:45
  3. LCD Showes Some Wrong Letters
    By sbobowski in forum General
    Last Post: - 23rd September 2008, 20:15
  4. Numbers and Letters After PIC Number
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 11th October 2007, 10:13
  5. Ditinguish between capital letters and small letters
    By egds in forum mel PIC BASIC Pro
    Last Post: - 14th September 2004, 14:13
