Active low transmitter question
Results 1 to 40 of 56
    Default Re: Active low transmitter question
    which in turn drives a loud sounder
    why a relay at all ? the 2n7000 could drive that alarm directly with ease
    Feb 2010
    I live in the UK
    I never thought of that, great idea, cheers Richard.
    What do you think the best way to drop the 12v from the sensor output to 3.3v into the pic, would the voltage divider be ok/work?
    works for me. you could protect against divider failure with a 3 to 5v zenner if you are paranoid
    the first pic may be unnecessary too if the tx works like i think it does
    Feb 2010
    I live in the UK
    works for me.
    Excellent, voltage divider it is then.
    Yes I do fit into that category (mildly at present), will look at at a backup with Zenner.
    I hear what your saying Richard, so I need to built the Tx cct on the bench now and test the Tx driven directly by voltage diver (no pic).
    Thanks for your help, appreciated.
    David
  1. better coding methods to freeing active ram in small pics
    Last Post: - 21st December 2012, 17:47
  2. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  3. Low Power Transmitter in a TO39 Package
    By BobP in forum Off Topic
    Last Post: - 29th October 2008, 10:28
  4. active LCD with input pen
    By micro in forum Off Topic
    Last Post: - 25th December 2005, 20:09
