Active low transmitter question
Results 1 to 40 of 56
    Feb 2010
    I live in the UK
    Default Re: Active low transmitter question
    Ok - So the transmitter will always Tx twice, on a button press to ground, then open contacts (if using a button). Or a transition from HIGH to LOW to High if using a pic GPIO pin to cause a Tx, correct?
    From the data sheet:
    'When configured as transmitter: Pins 3, 4, 7, 8, 9, 11, 12, 13 Inputs are internally pulled high, active low'
    So no pullup needed. How about if I set a TRIS bit to INPUT, corresponding GPIO pin left open but GPIO pin connected to Tx pin 3 say which is internally pulled HIGH, active low. Then when I want to TX, switch the TRIS bit to OUTPUT and pull the corresponding GPIO pin LOW then switch the TRIS bit to INPUT again mimicking a button press.
    Barking mad or genius?
    not genius yet
    not that i can see, there is no active low, a tx occurs on state change
    if tx telemetry mode engaged
    you need to explain what mode you are employing and what you are trying to achieve
    Feb 2010
    I live in the UK
    Hi Richard
    I got the idea of a Tx being initiated from the Data sheet 'When configured as transmitter: Pins 3, 4, 7, 8, 9, 11, 12, 13 Inputs are internally pulled high, active low'
    But as you and Ioannis both say a Tx occurs on a pin state change. I assumed that if a pin changed from HIGH to LOW and stayed in the LOW state the transmitter would continue to transmit being 'active low' but my knowledge is very limited I'll be the first to admit but always keen to learn.
    'you need to explain what mode you are employing and what you are trying to achieve'
    In the short term all I'm aiming to do is to have an input into a pic from a sensor trigger a Tx, and the Rx via another pic to trigger an alarm.
    Longer term, I'm fascinated by the idea of data transmission and would love to be able to configure a pic to transmit data - Set the Baud rate, SEROUT on Tx then SERIN and a lcd to read what's sent but that's for another day.
    Right now just a simple sensor (beam gets broken) set off a Tx, Rx to trigger an alarm on receipt via another pic.
    Feb 2010
    I live in the UK
    So to make the transmitter Tx once only, the way to do it is just have one pin state change - High to Low or Low to High?
    beam gets broken set off a Tx , Rx to another pic a beam broken state.
    beam gets restored set off a Tx , Rx to another pic a beam restored state.
    the remote end always reflects the "beam" state
    where is the problem ?
    why the tx once only obsession ?
    you might want to send a heartbeat to indicate tx link is active and working
    Feb 2010
    I live in the UK
    'you might want to send a heartbeat to indicate tx link is active and working'
    Good idea.
    'why the tx once only obsession ?'
    Not an obsession, I'm just trying to understand the mechanism here.
    Another Question:
    If an input pin is internally held HIGH and you put an external HIGH onto that pin, does the input pin 'see' the external HIGH as a state change? Or does it ignore it because it's internally held in a HIGH state already.
    logic pins by definition have two states high or low.
    a state change will be caused by any action that causes the pin voltage to reach
    the level of the logically opposite threshold
    so a low state is maintained until vih is reached
    a high state is maintained until vil is reached
    see data sheet for vih/vil threshold values
  1. better coding methods to freeing active ram in small pics
    Last Post: - 21st December 2012, 18:47
  2. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  3. Low Power Transmitter in a TO39 Package
    By BobP in forum Off Topic
    Last Post: - 29th October 2008, 11:28
  4. active LCD with input pen
    By micro in forum Off Topic
    Last Post: - 25th December 2005, 21:09
