Stepper motor question:
Results 1 to 7 of 7
    Alabama,USA
    Default Re: Stepper motor question:
    Thanks Alain
    Dec 2010
    Melbourne Australia
    Not necessarily. I've driven NEMA 35s and 42s at 250V without complaint - well, there might have been a hint of screaming Depends on how much they're loaded up and for what durations/duty cycles.
    Troy
    Quote Originally Posted by rocket_troy View Post
    Troy
    250v applied to +/- 1 Ohm ( NEMA 42 data ) create how much current ???
    You were joking, I suppose ...
    Stepper motor are meant to be driven by constant current drivers. In the good old days you had unipolar motors (center tapped windings) and drivers with BIG series resistors to limit the current to whatever the motor was designed for. These days stepper motor drives senses the current and control the output bridge (PWM) so that whatever current you set the driver to is what the motor gets. (And they sin/cos modulates the phase currents to get microstepping).
    You basically have to use a much higher voltage than what the nameplate rating says in order to counteract the inductance of the winding, if you don't you'll have a massively underperforming motor. Usually 10 to 20 times the rated voltage is common but sometimes it can be even more. I'm not surprised by the 250V figure mentioned for large NEMA42 motors.
    If you DO apply 5V directly across that motor winding you will damage the motor. You MUST limit the current to whatever the motor is designed for - one way or another. If there's no current rating printed on the motor, measure the resistance of the winding and calculate using Ohms law.
    Dec 2010
    Melbourne Australia
    Good explanation Henrik and my bad - I was feeding that voltage (it was actually 230V not 250V) into the driver, not directly into the stepper.
    Troy
  1. Motor Stepper Example
    Last Post: - 3rd January 2015, 18:58
  2. Stepper Motor Giveaway
    By rmteo in forum Off Topic
    Last Post: - 3rd June 2011, 23:43
  3. Stepper Motor Program
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 27th November 2007, 03:56
  4. Stepper Motor troubles
    By Fryin in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 02:56
  5. schema motor stepper
    By chip15 in forum mel PIC BASIC Pro
    Last Post: - 4th January 2006, 12:39
