SHIFTOUT MSB/LSBFIRST clarification
Results 1 to 18 of 18
    Jun 2008
    Varese , Italy
    Default Re: SHIFTOUT MSB/LSBFIRST clarification
    iT IS MY FAULT:
    Richard explanation is correct as usual !
    Thanks for all.
    All the best
    regards,
    Bye
    In the first post you said the number was 128 (10000000 in binary) so the MSB is indeed a '1'.
    But on the last post you saw a number 3 (00000011 in binary) so the MSB is a '0'.
    Jun 2008
    Varese , Italy
    thanks for the response,
    I had on my mund a shift register that will receive the serial stream from the PIC and I did associated the scope display to the shift register...
    I was in error when I thought that the first bit on the left hand side of the scope is the last transmitted by the PIC: the first bit bit on the left of the scope is the first transmitted and the last bit to the right is the last transmitted.
    Again, it was my fault .
    Thanks for the assistance.
    regards,Bye
  1. Need to flip order of bits MSB to LSB re: MCP23S17
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2015, 01:42
  2. MSB Compile error
    By RFEFX in forum PBP3
    Last Post: - 26th January 2015, 06:32
  3. DT Instant Interrupts - Clarification?
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 26th December 2013, 12:45
  4. Replies: 4
    Last Post: - 7th April 2013, 00:46
  5. Pro upgrade clarification
    By fowardbias in forum mel PIC BASIC Pro
    Last Post: - 24th January 2010, 21:17
