SHIFTOUT MSB/LSBFIRST clarification
Results 1 to 18 of 18
    Default Re: SHIFTOUT MSB/LSBFIRST clarification
    completely wrong , the first bit is on the left
    Jun 2008
    Varese , Italy
    could you please check in the real situation:
    connect the PIC DATA output to scope ch_1
    connect the PIC clock output to scope ch_2 and set the trigger to this channel.
    Tranmit bin 00000011 ( dec 3 ) \8 selecting MSB FIRST. and insert a small delay in the main loop just for better scope triggering. My scope is a old style !
    What do you see on the scope ? 00000011 or 11000000 ?
    Or better: do you see "11" to the right side or to the left side of the scope ?
    Thanks for helping
    regards
    You will send 00000011.
    Jun 2008
    Varese , Italy
    Hi Peter,
    could you please clarify better ?
    ( my English is not a first language )
    Jun 2008
    Varese , Italy
    iT IS MY FAULT:
    Richard explanation is correct as usual !
    Thanks for all.
    All the best
    regards,
    Bye
    In the first post you said the number was 128 (10000000 in binary) so the MSB is indeed a '1'.
    But on the last post you saw a number 3 (00000011 in binary) so the MSB is a '0'.
    Jun 2008
    Varese , Italy
    thanks for the response,
    I had on my mund a shift register that will receive the serial stream from the PIC and I did associated the scope display to the shift register...
    I was in error when I thought that the first bit on the left hand side of the scope is the last transmitted by the PIC: the first bit bit on the left of the scope is the first transmitted and the last bit to the right is the last transmitted.
    Again, it was my fault .
    Thanks for the assistance.
    regards,Bye
  1. Need to flip order of bits MSB to LSB re: MCP23S17
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2015, 01:42
  2. MSB Compile error
    By RFEFX in forum PBP3
    Last Post: - 26th January 2015, 06:32
  3. DT Instant Interrupts - Clarification?
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 26th December 2013, 12:45
  4. Replies: 4
    Last Post: - 7th April 2013, 00:46
  5. Pro upgrade clarification
    By fowardbias in forum mel PIC BASIC Pro
    Last Post: - 24th January 2010, 21:17
