SHIFTOUT MSB/LSBFIRST clarification
Results 1 to 18 of 18
    Default Re: SHIFTOUT MSB/LSBFIRST clarification
    which second was recorded first in time sequence ?
    slow your timbase right down , what direction does the dot travel
    the dot having writ moves on
    Jun 2008
    Varese , Italy
    the first bit sent out by the pic should be on the right ( 9 seconds old )
    The last bit sent by the pic should be on the left ( 0 seconds old )
    I am sorry for not understanding...
    thanks
    last try
    Jun 2008
    Varese , Italy
    thanks again,
    I am sorry for not understand...
    If I slow down the scope time base the dot goes from left to right.
    So the first bit transmitted by the PIC is always to the right of the scope and the last transmitted by the PIC is shown to the left.
    Am I right ?
    Then the 9 seconds old bit is the first transmitted by the PIC.
    The 0 secs old bit is the last transmitted by the PIC.
    Is it right ?
    Jun 2008
    Varese , Italy
    sorry: I did not tell that I am talking about the PIC output .
    completely wrong , the first bit is on the left
    Jun 2008
    Varese , Italy
    could you please check in the real situation:
    connect the PIC DATA output to scope ch_1
    connect the PIC clock output to scope ch_2 and set the trigger to this channel.
    Tranmit bin 00000011 ( dec 3 ) \8 selecting MSB FIRST. and insert a small delay in the main loop just for better scope triggering. My scope is a old style !
    What do you see on the scope ? 00000011 or 11000000 ?
    Or better: do you see "11" to the right side or to the left side of the scope ?
    Thanks for helping
    regards
    You will send 00000011.
    Jun 2008
    Varese , Italy
    Hi Peter,
    could you please clarify better ?
    ( my English is not a first language )
  1. Need to flip order of bits MSB to LSB re: MCP23S17
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2015, 02:42
  2. MSB Compile error
    By RFEFX in forum PBP3
    Last Post: - 26th January 2015, 07:32
  3. DT Instant Interrupts - Clarification?
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 26th December 2013, 13:45
  4. Replies: 4
    Last Post: - 7th April 2013, 01:46
  5. Pro upgrade clarification
    By fowardbias in forum mel PIC BASIC Pro
    Last Post: - 24th January 2010, 22:17
