12F675 vs 12F1840
Results 1 to 6 of 6
    Default 12F675 vs 12F1840
    I had a test program developed on 12F675 until my samples of 12F1840 arrive.
    Now I transferred the exact same code to the 1840 chip and the size of compiled code went from 547 words to 785 words.
    I thought maybe the x8 system clock of 1840 could affect code size but when compiled as 4MHz (just as the 12F675) the code went up to 794!!!
    It is not critical obviously for my project, just curious why that happens.
    Default Re: 12F675 vs 12F1840
    Forgot to change GPIO to LATA and PORT registers.
    Now it counts down to 679 words. But still away from 547 words.
    Intersting, still ~25% larger compared to 12F675.
    The 12F1840 has a larger instructionset than the old 675 so one would think there would be "better" ways to do things on the 1840 (though PBP most likely uses the same library for both devices) - which then raises the question: Why so much larger?
    Care to post the actual code so we can take a look and perhaps learn something?
    I shouldn't but for the sake of the very strange case I will. On both the chips the code is the same except for the port access. Everything else is identical.
    12F675:
    #config
      __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _CP_ON
    #endconfig
    DEFINE OSCCAL_1K 1 	'Read OscCal value from the last location
    'DEFINE PULSIN_MAX 2000
    'DEFINE ADC_CLOCK 3   'INTERNAL A/D RC CLOCK
    'DEFINE ADC_SAMPLEUS 50  'SET SAMPLE TIME IN MICROSECONDS
    'DEFINE ADC_BITS 8
    INTCON = $00
    TRISIO = %00011101
    CMCON=7
    OPTION_REG.0=0		'PSA0 PRESCALER SELECT 1:1 TO 1:256
    OPTION_REG.1=0		'PSA1
    OPTION_REG.2=0		'PSA2
    OPTION_REG.3=0		'PRESCALER TO: 1->WDT, 0->TMR0
    OPTION_REG.4=0		'T0SE SOURCE EDGE 1->H TO L, 0->L TO H
    OPTION_REG.5=0		'T0CS 1->FROM RA4, 0->FROM INT. CLOCK
    OPTION_REG.6=1		'INT EDGE SELECT 0->H TO L, 1->L TO H
    OPTION_REG.7=0		'PULL UP 1->DISABLE, 0->ENABLE
    WPU=%00000101
    ADCON0 = %00001101	' Configure and turn on A/D Module:
    					' Right justify result, AN3 in on GP4
    'adcon 7 ADFM: A/D Result Formed Select BIT
    '				1 = Right justified
    '				0 = Left justified
    'adcon 6 VCFG: Voltage Reference BIT
    '				1 = VREF pin
    '				0 = VDD
    'adcon 5-4 Unimplemented
    'adocn 3-2 CHS1:CHS0: Analog Channel Select bits
    '				00 = Channel 00 (AN0)
    '				01 = Channel 01 (AN1)
    '				10 = Channel 02 (AN2)
    '				11 = Channel 03 (AN3)
    'adcon 1 GO/DONE: A/D Conversion Status BIT
    '				1 = A/D conversion cycle in progress.
    '				0 = A/D conversion completed/NOT in progress
    'adcon 0 ADON: A/D Conversion STATUS BIT
    '				1 = A/D converter module Is operating
    '				0 = A/D converter Is shut-off AND consumes no operating current
    ANSEL = %00111000 	' Set ADC clock to Frc and GP1 to analog mode
    servo	VAR	GPIO.5	'PIN# 2, Prog. Button
    ldr 	VAR GPIO.4 	'PIN# 3, Direction control and LED
    prog	VAR GPIO.3	'PIN# 4, MCLR/RS232 Receive
    down	VAR GPIO.2	'PIN# 5, RS232 Transmit/Receive
    led 	VAR GPIO.1	'PIN# 7, Analog input
    up      var gpio.0
    pos         var word
    timer       var byte
    adval       var byte
    flag1       vAR BIT
    i           var byte
    up_lim      var word
    down_lim    var word
    max_up      var word
    max_down    var word
    ldr_l       var byte
    data @0,word 2100,word 550,word 2100,word 550,230
    high led
    read 0,word up_lim,word down_lim,word max_up,word max_down,ldr_l
    while 1
        if !prog then gosub setup
        gosub ldr_sub
        gosub servo_sub
        timer=timer+1
        if timer>50 then
            timer=0
            low led:pause 10:high led
    wend
    setup:
        if prog then return
        while !prog:pause 100:toggle led:wend
        high led
    setup1:
        pos=up_lim:gosub servo_sub1
        if !up then
            up_lim=up_lim+10
            if up_lim>max_up then up_lim=max_up
            low led:pos=up_lim:gosub servo_sub1:high led
        if !down then
            up_lim=up_lim-10
            if up_lim<(max_down+10) then up_lim=(max_down+10)
        if prog then setup1
        high LED
    setup2:
        pos=down_lim:gosub servo_sub1
        if !up then
            down_lim=down_lim+10
            if down_lim>(max_up-100) then down_lim=(max_up-100)
            low led:pos=down_lim:gosub servo_sub1:high led
        if !down then
            down_lim=down_lim-10
            if down_lim<max_down then down_lim=max_down
        if prog then setup2
        GOTO EXIT_SETUP
    setup3:
        if !up then
            LDR_L=LDR_L+5
            if LDR_L>250 then LDR_L=250
            low led:PAUSE 20:high led:pause 50
        if !down then
            LDR_L=LDR_L-5
            if LDR_L<100 then LDR_L=100
        if prog then setup3
    exit_setup:
        high led
        while !prog:pause 100:wend
        write 0,word up_lim,word down_lim',LDR_l
        for i=0 to 3
            low led:pause 250:high led:pause 250
        next i
    servo_sub:
        if flag1 then
            pos=up_lim
            pos=down_lim
    servo_sub1:
        high servo:pauseus pos:low servo
        pause 19
    ldr_sub:
        adcon0.1=1
        while adcon0.1:wend
        select case adresh
            case is < ldr_l
                flag1=0
            case is > (ldr_l+10)
                flag1=1
        end select
    12F1840
     ;----- CONFIG1 Options --------------------------------------------------
     __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_OFF
     ;----- CONFIG2 Options --------------------------------------------------
     __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
     ' SYSTEM INITIALIZATION
     PORTA = %00000000
     TRISA  = %00001111	   ' Make A0,A2,A3 inputs,A1,A4,A5 outputs
     OSCCON = %11110000 'PLL ENABLED,8Mhz,FSOSC<2:0>
     OSCTUNE	= %00000000	' Internal osc Adjustment
    WHILE !OSCSTAT.3	' Wait for stable OSC ...
    WEND
     INTCON = %00000000 'CLEAR GIE,PEIE,TMR0IE,INTE,RBIE,TMR0IF,INTF,RBIF
     PIE1 = %00000000 'CLEAR ALL INTERRUPT ENABLE BITS
     PIR1 = %00000000 'CLEAR ALL INTERRUPT FLAGS
     PIE2 = %00000000 'CLEAR ALL INTERRUPT ENABLE BITS
     PIR2 = %00000000 'CLEAR ALL INTERRUPT FLAGS
     APFCON = %00000000 'ALL DEFAULTS
     ANSELA = %00000010    'Select digital/analog pins
     CPSCON0 = %00000000 'ENABLE CAP SENSE,DAC/FVR,HIGH RANGE
     WPUA	= %00001101    'weak pull ups
     ADCON0 = %00000101 'CHS2:0,GO/DONE,ADOFF
     ADCON1 = %00110000 'LEFT JUSTIFIED,FRC,VSS,VDD
     SRCON0 = %00000000
     SRCON1 = %00000000
     CM1CON0 = %00000000 'CLEAR/DISABLE COMPARATOR
     CM1CON1 = %00000000 'CLEAR/DISABLE COMPARATOR
     DACCON0 = %00000000 'ENABLE DAC,ENABLE POS REFERENCE,SOURCE IS FVR
     DACCON1 = %00000000 'SET FOR 1/4 SCALE (8) ~ 1.024
     FVRCON = %00000000 'ENABLE VOLTAGE REFERENCE,4,096
     OPTION_REG = %00000000 'INTEDG,T0CS,T0SE,PSA,PS
     T1CON = %00000000 'CAPOSC INPUT,PRESCALER 1/1,START TIMER 1
     T1GCON = %00000000 'NO GATE CONTROL
     T2CON = %00000000 'POSTSCALER 1/1,STOP,PRESCALER 1
     TMR2 = 0 'CLEAR TMR2 MODULE REGISTER
     PR2 = 255 'SET PERIOD ((((1 / 32,000,000)*4) * 1 PRESCALE) * (1+255 PR2)) = 31.25 KHZ.
     CCP1CON = %00000000 'PLACE CCP1 INTO DISABLE MODE
     CCPR1L = $00 'CLEAR CCP1 LOWER 8 BITS
     CCPR1H = $00 'CLEAR CCP1 UPPER 2 BITS
     PSTR1CON = %00000001'DEFAULT
    DEFINE OSC 32
    servo	VAR	lata.5
    led 	VAR lata.4
    prog    VAR porta.3
    down	VAR porta.2
    ldr 	VAR porta.1
    up      var porta.0
    pos         var word
    timer       var byte
    adval       var byte
    flag1       vAR BIT
    i           var byte
    up_lim      var word
    down_lim    var word
    max_up      var word
    max_down    var word
    ldr_l       var byte
    data @0,word 2200,word 550,word 2200,word 550,230
    'data @0,word 550,word 2200,word 550,word 2200,230
    high led
    while 1
        gosub ldr_sub
        gosub servo_sub
        timer=timer+1
        if timer>50 then
            timer=0
    wend
    setup:
        if prog then return
        high led
    setup1:
        if !up then
            up_lim=up_lim+10
        if !down then
            up_lim=up_lim-10
        if prog then setup1
        high LED
    setup2:
        if !up then
        if !down then
        if prog then setup2
        GOTO EXIT_SETUP
    setup3:
        if !up then
            LDR_L=LDR_L+5
        if !down then
            LDR_L=LDR_L-5
        if prog then setup3
    exit_setup:
        high led
        for i=0 to 3
        next i
    servo_sub:
        if flag1 then
            pos=up_lim
            pos=down_lim
    servo_sub1:
        pause 19
    ldr_sub:
        adcon0.1=1
        while adcon0.1:wend
        select case adresh
            case is < ldr_l
                flag1=0
                flag1=1
        end select
    Most strange is the 32 vs 4 MHz clock. Lower clock needs more code space!!! I expected the oposite.
    Hi, Ioannis,
    I'd have a look to internal registers PBP default settings ( the PBP default Config file ) ... as you overwrite most of them ...
    just an idea ...
  1. 12F1840 ADCIN troubles, help needed :(
    Last Post: - 7th December 2015, 14:18
  2. 12F1840 config issues
    By enigma in forum PBP3
    Last Post: - 15th February 2015, 07:49
  3. Problem converting 12F683 code to 12F1840
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 14th March 2013, 01:55
  4. PBP Support for 12F1840 8-Pin Device?
    By springtank in forum mel PIC BASIC Pro
    Last Post: - 10th November 2012, 08:32
  5. 12f675
    By mystified in forum mel PIC BASIC
    Last Post: - 10th September 2007, 02:47
