If ... THEN @ NOP
Results 1 to 4 of 4
    Default If ... THEN @ NOP
    Could someone explain ...
    IF ACLine == 0 THEN
    @ NOP  	' read Line input
    THIS works ...
    IF ACLine == 0 THEN @ NOP  	' read Line input
    THIS Generates an error ...
    Sep 2009
    Default Re: If ... THEN @ NOP
    @ symbol is for replacing ASM ENDASM. It should be first charter on that line, so it will indicate that line is ASM.
    So try to write If ... THEN ASM NOP ENDASM
    Hi, Pedja
    doesn't work Either ...
    C:\USERS\ACETR\DOCUMENTS\PROJETS_MCHIP\THERPICPOUL _TR.BAS ERROR Line 257: Bad expression.
    C:\USERS\ACETR\DOCUMENTS\PROJETS_MCHIP\THERPICPOUL _TR.BAS ERROR Line 257: Bad expression or missing THEN.
    C:\USERS\ACETR\DOCUMENTS\PROJETS_MCHIP\THERPICPOUL _TR.BAS ERROR Line 257: IF without a matching ENDIF.257: Syntax error
    257: Syntax error
    Sep 2009
    I expected that...
    Then you must press enter two more times
  1. Null statement (NOP or CONTINUE)
    By RussMartin in forum General
    Last Post: - 4th February 2009, 22:28
  2. How do I put a NOP at location 0 for the ICD2 by use PBP?
    By Worayoot in forum mel PIC BASIC Pro
    Last Post: - 7th April 2004, 06:04
