HT16K33 led 14 segment backpack
Results 1 to 9 of 9
    Default HT16K33 led 14 segment backpack
    Hi folks,
    I want to ask members, someone has done working with this HT16K33 14. segment LED backpack in PBP.
    https://www.adafruit.com/product/1911
    I am trying to get this thing live, but no success. Any help welcome.
    Thanks.
    Louis
    Default Re: HT16K33 led 14 segment backpack
    i did post an example but its been expunged or lost when the forum crashed, all i can find on my pc is this
    ;7x5 led array witk ht16k33  mapped col 0-5  a0 - a6;highbyte of ROW[x] maps to a0:7  i2cread/write natively sends high byte first.
    ;chip actually wants data lowbyte first   ~! typical
    ;pic12f1822
        __config _CONFIG1, _FOSC_INTOSC & _MCLRE_ON & _CP_OFF & _CPD_OFF
        __config _CONFIG2, _PLLEN_OFF & _LVP_OFF
    OSCCON = %01110000
    DEFINE OSC 8
    TRISA = %001011
    ANSELA = 0				'Digital
    '    DEFINE DEBUG_REG PORTA
    '    DEFINE DEBUG_BIT 0      ;  if not used for pwr
    '    DEFINE DEBUG_BAUD 9600
    '    DEFINE DEBUG_MODE 0
    '    pause 2000
    '    Debug "Start",13 ,10
    ' DISPLAY ON  0X21
    ' NO BLINK    0X81
    ' ROW/INT     0XA0
    ' BRIGHT      0XEX
     scl var portA.4
     sda var portA.5
     Led var LATA.2
     SADD VAR BYTE
     ROW VAR WORD[5]
     COL var byte
     TMP VAR WORD
     CLEAR
     INIT:
     i2cwrite sda,scl,$E0,[$21] 'on
     i2cwrite sda,scl,$E0,[$81] 'blink off
     i2cwrite sda,scl,$E0,[$E8] 'HALF BRIGHT
     i2cwrite sda,scl,$E0,[$A0] 'NO INT
     i2cwrite sda,scl,$E0,[SADD,ROW,ROW,ROW,ROW,ROW] ;CLEAR
        COL=35
        while col        ;walk a led backwards through array
            col=col-1
            TMP=0
            TMP.0[14-(COL/5)]=1
            SADD = 5
            WHILE SADD
                SADD=SADD-1
                ROW[SADD]=0
            WEND
            ROW[(COL//5)]=TMP
            i2cwrite sda,scl,$E0,[SADD,ROW[0],ROW[1],ROW[2],ROW[3],ROW[4]]
        wend
        SADD = 0
        FOR ROW=0 TO 127
            ROW=ROW<<8
            i2cwrite sda,scl,$E0,[SADD,ROW,~ROW,ROW,~ROW,ROW]
            pause 50
            ROW=ROW>>8
        NEXT
        FOR COL=0 TO 34
            TMP=0
    '        SADD=COL//5
            TMP.0[14-(COL/5)]=1
    '        Debug 13,10,#COL,9,HEX TMP,9,#SADD
            SADD = 5
            WHILE SADD
                SADD=SADD-1
                ROW[SADD]=0
            WEND
            ROW[(COL//5)]=TMP
        NEXT
        LED=!LED
    Thanks for reply. Not working but now more clear for me how to handle this controller. I tried init the controller with default I2c adress $70 like this:
    ;pic 12F1840
    OSCCON = %01110000
    DEFINE OSC 8
    TRISA = %000000
    ANSELA = 0				'Digital
     scl var portA.2
     sda var portA.1
     SADD VAR BYTE
     ROW VAR WORD[5]
     COL var byte
     TMP VAR WORD
     CLEAR
     INIT:
     i2cwrite sda,scl,$70,[$21] 'on
     i2cwrite sda,scl,$70,[$81] 'blink off
     i2cwrite sda,scl,$70,[$E8] 'HALF BRIGHT
     i2cwrite sda,scl,$70,[$A0] 'NO INT
     i2cwrite sda,scl,$70,[SADD,ROW,ROW,ROW,ROW,ROW] ;CLEAR
    pause 200
    ;send something
    row=5
    SADD=1
    i2cwrite sda,scl,$70,[SADD,ROW[0],ROW[1],ROW[2],ROW[3],ROW[4]]
    No sign of life.
    No sign of life.
    would not expect any with $70 as an address , if you have a ht16k33 the address is %1110xyz0 where xyz are a2 a1 a0
    if a0-a2 are set low the the address is $e0 as per my example
    not only that row[0] to [4] are set to 0 still
    ;pic 12F1840#CONFIG
    OSCCON = %01110000
    DEFINE OSC 8 TRISA = %000000
    ANSELA = 0				'Digital
    scl var portA.2
    sda var portA.1
      SADD VAR BYTE
    ROW VAR WORD[4]
    COL var byte
    TMP VAR WORD
    CLEAR
    INIT:
     i2cwrite sda,scl,$e0,[$21] 'on
    i2cwrite sda,scl,$e0,[$81] 'blink off
    i2cwrite sda,scl,$e0,[$E8] 'HALF BRIGHT
    i2cwrite sda,scl,$e0,[$A0] 'NO INT
     i2cwrite sda,scl,$e0,[SADD,ROW,ROW,ROW,ROW] ;CLEAR
    pause 200;send something
    row[0]=5:row[1]=4:row[3]=2:row[0]=1
    SADD=1 ; not sure about this might need to be 0
    i2cwrite sda,scl,$70,[SADD,ROW[0],ROW[1],ROW[2],ROW[3]]
    That default address I got from product listing:
    IIC address: default address 0X70
    A0, A1, A2,: IIC data address control terminal
    IIC address calculation: 0X70+A0+A1+A2 (floating is 0, shortet A0 is 1, A1 is 2, A2 is 4,
    for example A0 and A2 is shorted the IIC address at this time = 0X70+1+4=0X75)
    that's for a 7 bit i2c address scheme, arla arduino. pbp uses an 8 bit address for i2c
    Of course, you're right. Now something happening. The display lit up and does some counting and flickering with segments.
    That with your firstly posted code. Now figuring out how to display numbers and characters.
    don't lose sight of the fact that my code is for a 5 x 7 bit matrix , you have a 4 x 14 bit alpha led's
  1. 7 segment led displays
    By raybel in forum FAQ - Frequently Asked Questions
    Last Post: - 12th September 2013, 18:22
  2. Seven Segment LED
    By Brian in forum mel PIC BASIC Pro
    Last Post: - 5th May 2011, 05:26
  3. Replies: 3
    Last Post: - 5th December 2008, 16:00
  4. Dual 7-segment LED display counter
    By mosbc69 in forum mel PIC BASIC Pro
    Last Post: - 17th November 2008, 23:53
  5. Dual 7-Segment LED Display
    By erice1984 in forum Schematics
    Last Post: - 3rd July 2007, 00:51
