Microchip SST26VF064B (64Mbit Serial Flash)
Results 1 to 6 of 6
    Jun 2005
    West Australia
    Default Re: Microchip SST26VF064B (64Mbit Serial Flash)
    Hi Richard,
    I take your point however in my logging application I don't need a file system.
    Presently data is being streamed via 4G and the planned logger will be there only to safeguard against Telstra comms failures - not frequent but has occurred leaving 'holes' in data that compromises the modelling. After such an event a second modem port will allow a remote connection to interrogate the logger, search for the time/date wanted and download the missing information.
    I plan on using the Flash as a lump of memory with each 15byte record [GPS time/date stamped+data] being written contiguously. The only housekeeping necessary will be to stay within the bounds of the device's page/block and address limits. I'm using a large Flash size to maximize time before overwriting of cells becomes necessary and expect to get near 1 year of 1 minute records before this happens.
    Any further thoughts or comments you may have are welcome.
    Cheers,
    Bill
    which is what I did. its a way to break up the flash data space
    enabling reading, writing and erasing of data in a pic sized way
    yet deal with large data structures normally beyond a pic's scope.
    just looking at that requirement makes me think a sudo file structure
    would be an enormous advantage ,
    think of flash structure , 125 64k blocks , each block has 16 4k pages .
    each page could hold 256 16 byte records depending on how many records per day/week whatever will fit in a block. eg. a new block[file] every fortnight
    a new page every day sort of thing makes life easy
    {its what i use , a record ever 6 mins) [if your storage is timed accurately the timestamp is redundant]
    you can do a bit of wear levelling by offsetting the day page and have a simple ring structure
  1. Spi flash chip example - 8mb flash
    By longpole001 in forum Code Examples
    Last Post: - 1st August 2014, 11:00
  2. AT45 Flash problems
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 19th November 2008, 00:42
  3. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 13:27
  4. NEXFLASH serial flash
    Last Post: - 11th July 2004, 20:10
  5. Replies: 0
    Last Post: - 18th November 2003, 08:24
