12F1572 HPWM issue
Results 1 to 3 of 3
    Jan 2014
    Default 12F1572 HPWM issue
    HPWM work right on PORTA.1 . Also , the PORTA.5 work well like a digitall port.
    I want to move the PWM1 from PORTA.1 to PORTA.5 . Theoretically is very simple, must set APFCON.0 =1 .
    Now I have a problem because on pin A5 I have nothing, also, the HPWM is missing on pin A.1 .
    I changed the PIC from another lot , but the same !
    If I set APFCON.1 = 1 , the PWM2 is moved from A.0 to A.4, so the APFCON have an effect.
    Something is missing or chip have some trouble ?
            __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _BOREN_OFF & _CLKOUTEN_OFF
            __config _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_LO & _LPBOREN_OFF & _LVP_OFF
    DEFINE OSC 4	' system clock at 4MHz
    OSCCON = %01101010
    DEFINE HPWM_OSC  16000000	' PWM clock at 16MHz
    APFCON.0 = 1
    ANSELA = %00000000
    PORTA  = %00000000
    hpwm 1 , 100, 16000 'PORTA.5
    Default Re: 12F1572 HPWM issue
    try
    DEFINE CCP1_REG PORTA 'Channel-1 port
    DEFINE CCP1_BIT 5 'Channel-1 bit
    and maybe
    trisa.5=0
    Jan 2014
    Now is working...
    Was necesary only to set the port RA.5 as output . Its iteresting that portA5 work well as digitall output pin but did'n work as PWM pin only if its set to output.
    Thank you very much Richard !
  1. 12f1572
    By Rony in forum General
    Last Post: - 28th January 2017, 16:27
  2. IF-THEN issue
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 12th February 2014, 22:09
  3. Replies: 3
    Last Post: - 23rd October 2011, 12:53
  4. Code Issue - select case or 'if' issue - not sure why
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 7th October 2007, 08:52
  5. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
