Graphical Displays with PBP3
+ Reply to Thread
Results 1 to 40 of 117
    Default Re: Graphical Displays with PBP3
    in theory portrait mode should be easier and faster than what i have now, the screen width 64 height 128
    and the buffer sent to the screen in horiz fill mode nice and sequentially [ might need bit reversal, could be upside down or mirrored]
    i will have a look one day time permitting
    a portrait version
    '*  Name    : SSD1306p.pbpmod                                          *
    '*  Author  : richard                                                 *
    '*  Notice  : Copyright (c) 2021                                      *
    '*  Date    : 28/12/2023                                              *
    '*  Version : 1.1                                                     *
    '*  Notes   : generic GRX graphics DRIVER FOR SSD1306                 *
    '*          :  HW I2C PIC18 ONLY                                      *
    '*          :  40x72 disp added                                       *
    '*          :    portrait version                                                     *
           ;set these  to match display IN MAIN
    '    ssd1306_addr con $78
    '    #DEFINE colours 1   ;1 mono 2 rg or 3 rgb
    '    width  con 128
    '    height con 32
    '    h_offset con 0   ;28 for 40x72
        glrot       var byte[8]
        glrb        var byte[8]
        gltmp       var byte[3]
        glcd_rad    var WORD
        glcdData    VAR byte  'DATA
        glcdBC      VAR BYTE  'gca  var
        page        VAR WORD  'gca  var
        gy          var byte  'gca  pg   address
        gy_         var byte  'gca  pg   address
        gx          var byte  'gca  row  address
        gx_         var byte  'gca  row  address
        ssd_add     var byte
        USERCOMMAND "SENDBYTE"     ;BYTE
        USERCOMMAND "SSDC"      ;cmd BYTE TO SSD1306
        ssdheight con WIDTH/8-1      ; 7 = 8 PAGES  64*128 ,  3 = 4 pages 32*128
        ssdwidth  con HEIGHT-1    ; 128 PIXELS WIDE
    goto overssd
    SSDC?C  macro Cin
        MOVE?CB  Cin , _glcdData
        L?CALL   _cmd_byte
    SSDC?B  macro Cin
        MOVE?BB  Cin , _glcdData
        L?CALL   _cmd_byte
    SENDBYTE?B  macro Dat
        MOVE?BB    Dat ,_glcdData
        L?CALL _send_byte
    SENDBYTE?W  macro Dat
        MOVE?WB    Dat ,_glcdData
        L?CALL _send_byte
    SENDBYTE?C  macro Dat
        MOVE?CB    Dat ,_glcdData
        L?CALL _send_byte
    glcd_init:
        bgcolour = 0
        colour  = 1
        SSPSTAT = 0 'High Speed Filter
        SSPADD = $14'400 kHz @64 MHz  ?
        SSPCON1 = 101000 'I2C Master Mode Enable
        SSPCON3 = 0
        ssd_add = ssd1306_addr
        SSDc $AE ' Display OFF
        SSDc $d5
        SSDc $80
        SSDc $a8 : SSDc $3f
        SSDc $D3 : SSDc $00 ; Set Display Offset Mode Set 0
        if ssdheight > 4  then
            SSDc $40   ' Set display start line 0
        elseif ssdheight > 3  then
            SSDc $68   ' Set display start line
            SSDc $60   ' Set display start line 4
        SSDc $8D : SSDc $14 ' Set Charge Pump Internal
        SSDc $20 : SSDc $01 ' Adressing mode Horizontal
        SSDc $A1   ' set segment remap column 127 as start
        SSDc $C0   ' Com Scan Direction, Flip display vertically
        SSDc $DA   ' set COM pins
            SSDc$12  ' set COM pins = 128x64=$12
            SSDc$02  ' set COM pins = 128x32=$02
        SSDc $81 : SSDc$7F  ' Set brightness to $01 to $FF  ($7F is default, $01 is faint)
        SSDc $DB : SSDc$40  ' Set VCOM Deselect Level
        SSDc $B0  ' Set Page Address From $B0 to $B7
        SSDc $2e  ; scroll off
        SSDc $A4  ' display ON continue
        SSDc $A6  ' $A6=NORMAL MODE;  $A7=INVERSE MODE
        SSDc $AF  ' Display ON
    show:
    '    gosub flip
        SSDc $22
        SSDc  0
        SSDc  ssdheight
        SSDc $21
        SSDc  h_offset
        SSDc  ssdwidth + h_offset
        SSPCON2.0 = 1 ; SEN - Start Condition Enable Bit
        WHILE SSPCON2.0 = 1 : WEND ; Wait for Start to complete
        SSPBUF = ssd_add ; Move data to SSPBUF
        WHILE SSP1STAT.2 = 1 : WEND ; SSPSTAT = 1 Transmit in progress
        While SSP1CON2.6 = 1 : WEND ; Wait for Acknowledge from slave
        SSPBUF = $40 ; Move data to SSPBUF
        WHILE SSPSTAT.2 = 1 : WEND ; SSPSTAT = 1 Transmit in progress
        While SSPCON2.6 = 1 : WEND ; Wait for Acknowledge from slave
        for glcd_rad = 0 to  width/8 * height -1
            SENDBYTE fbr[glcd_rad ]
        next
        SSPCON2.2 = 1
    '    gosub flip
    send_byte :  'DATA
        SSPBUF = glcdData; Move data to SSPBUF
    cmd_byte:  'send command sequence "glcdData "
        SSPBUF = 0 ; Move data to SSPBUF
        SSPBUF = glcdData ; Move data to SSPBUF
        SSPCON2.2 = 1 ; PEN - send stop bit
        While SSP1CON2.2 = 1 : Wend ; Wait for SSP to complete
     overssd:
    with demo
    'PIC18F26K22#CONFIG
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = ON
      CONFIG  PRICLKEN = ON
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = ON
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  T3CMX = PORTC0
      CONFIG  HFOFST = ON
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    DEFINE OSC 64
        clear
        width  con 64
        height con 128
        h_offset con 0
        DEFINE DEBUG_REG PORTB
        DEFINE DEBUG_BIT 7
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        LATB.7=1
        trisb.7=0
        include "grx.pbpMOD"
        include "SSD1306p.pbpMOD"
        include "font.bas"
        BUFF     VAR BYTE[32]
        ANSELB=0
        ANSELC=0
        ANSELA=0
        OSCCON=$70
        OSCTUNE.6=1
        SETFONT FONT5x7
        gosub glcd_init
       gosub grf_clr
        gosub show
        ARRAYWRITE BUFF,["GLCD",0]
        DMDSTR 3,75,buff,1
        DMDBMP 0,0,TestIcon
        gosub show
        pause 5000
    TestIcon:
    @ db 0x10,0x10 ;16x16
    @ db 0xFF,0xFF;
    @ db 0xC0,0x03;
    @ db 0xA0,0x05;
    @ db 0x90,0x09;
    @ db 0x88,0x11;
    @ db 0x84,0x21;
    @ db 0x82,0x41;
    @ db 0x81,0x81;
    @ db 0x81,0x81;
    @ db 0x82,0x41;
    @ db 0x84,0x21;
    @ db 0x88,0x11;
    @ db 0x90,0x09;
    @ db 0xA0,0x05;
    @ db 0xC0,0x03;
    @ db 0xFF,0xFF;
    Apr 2007
    Pennsylvania, USA
    Excellent work Richard!!!
    This will work well for my use, but with a little more tweaking it would be nice to have a define to set 1 of 4 different viewing directions to make a more universal driver.
    Shawn
    Dec 2010
    Melbourne Australia
    Hi Richard,
    I've been using your display drivers with 12864 ST7920 LCDs and one thing that's annoying (for me) is randomly on startup I'll be getting 3 large(ish) zeros in the top left corner of the display. If they appear, there's no getting rid of them without cutting power to the display. Any idea what I'm missing here? I can still write stuff to the display, but the zeros will remain there irrespective of screen clearing. Even filling the screen with a filled (black) rectangle - the zeros are still there but just colour inverted.
    You can see if they're going to appear with the initialisation call to st7920_init as the areas around there is more populated with random dots than neighbouring areas. Sometimes it's clear enough to make them out before calling a screen clear and show.
    Could this be a timing problem on my initialisation? It's happened on various displays (same model) and various completely different programs.
    Troy
    most likely, the displays have two screen memory regions one for graphics the other for the normal lcd character display
    at power up display is in lcd mode, the init routine sets it to graphics, lcds are slow to powerup they cannot be hurried.
    if the display is written to before graphics mode is established then its possible some lcd chrs will be displayed accidently.
    lcd chrs can only be cleared if the display is in lcd mode , graphic pixels can only be set in graphics mode
    both memories are visible on screen no matter what mode is set.
    Dec 2010
    Melbourne Australia
    Yeah, what you've said does make sense. I've played around with all sorts of timings - like up to 10s pause after calling the st7920_init and 2s prior, but I don't think it's my writing to the display that's causing the issue as the signs are already there when I call st7920_init.
    So, are you aware of any commands I can call to initialise the "character" memory before calling st7920_init?
    Troy
    as in my demo
        Pause  1500      ' LCD initialize time
        lcdout $FE,1
        gosub st7920_init    'graphic mode
  1. Replies: 3
    Last Post: - 1st January 2021, 21:28
  2. problem using Graphical LCD
    By Mostafa in forum mel PIC BASIC Pro
    Last Post: - 18th July 2007, 18:15
  3. Graphical LCDs
    By T.Jackson in forum General
    Last Post: - 14th May 2007, 06:29
  4. Vb 6.0 Graphical plug in
    By rocky79 in forum Serial
    Last Post: - 8th March 2006, 18:42
  5. Graphical user interface
    By rocky79 in forum mel PIC BASIC Pro
    Last Post: - 15th October 2005, 12:25
Members who have read this thread : 9
