Bumpless Transfer PIC18F
Results 1 to 5 of 5
    Default Bumpless Transfer PIC18F
    I have a pic 18F project which has incoming data every 10ms in a word.
    The top nibble of the word high byte is flags, either %1111 or 0000 (we can ignore/mask them out)
    The lower 12 bits is a value 0-4095
    If a button is pressed I modify the 12 bit value and then send it back out again.
    If the button is not pressed the data passes through unchanged.
    All good so far!
    Now if the incoming 12 bit data is say 4095, I want to modify that to be 0 and send it out with a gradual change.
    When my button is released I want the same thing to happen in reverse i.e. change from 0 back to the 4095.
    I basically want the system to smoothly change from the incoming value to mine and back again in say 500ms.
    So maybe increments of 80 every 10ms>
    I believe this sort of transition is caused 'bumpless transfer' so was wondering if anyone had any clever ideas or code for it..
    Default Re: Bumpless Transfer PIC18F
    looks like a pretty classic state machine solution would be in order
    enum state [idle, beginning, held , releasing]; button states
    process each incoming val according to present state
    while state idle: full pass val
    transition --> to beginning, redux = 80 ,pass val-redux, transition --> state to held ; [button pressed detected]
    while state held: pass val-redux , redux += 80 until redux=val ; [button held]
    transition --> to releasing ,redux -= 80 ; pass val-redux, [button release detected]
    while state releasing: pass val-redux , redux -= 80 , until redux=0 ,transition --> state to idle
    What if the incoming value changes as the output is ramping towards one end? Should that change in input signal be ignored or should there be an equal change in the output?
    i would expect 'bumpless transfer' to mean that the final condition should gently ramp back up to the initial condition
    so as to to not cause alarming output swings after manual intervention is completed. the incoming input during the
    "tampering process" would be irrelevant in that case
    We can ignore the incoming signal during the period it is being replaced/overridden,
    but as soon as the manual intervention is finished the system needs to gently return to what the incoming signal is saying.
  1. PIC18F got some weird problem?
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 19th February 2007, 16:18
  2. Starting with PIC18F
    By Gérard in forum mel PIC BASIC Pro
    Last Post: - 7th May 2006, 16:40
  3. PIC18F and Profibus
    By boboco in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 08:37
  4. RS232 & PIC18F
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 15th June 2005, 14:13
  5. Selfprogramming Pic18F over GSM
    By Tomasm in forum mel PIC BASIC Pro
    Last Post: - 19th May 2004, 00:29
