HSEROUT using STR modifier - length parameter as variable not working
Results 1 to 15 of 15
    Default Re: HSEROUT using STR modifier - length parameter as variable not working
    it fails of course for more than 255 chrs
    BalBuffer VAR BYTE[300]
    BalCount VAR word
    latb.7=1
    clear
    for   BalCount= 0 to 59
    BalBuffer[BalCount]=BalCount+"0"
    next
    for   BalCount= 1 to 59
    BalBuffer[BalCount+60]=BalCount+"0"
    next
    BalBuffer[BalCount+120]=BalCount+"0"
    next
    BalBuffer[BalCount+180]=BalCount+"0"
    next
    BalBuffer[BalCount+240]=BalCount+"0"
    next
    BalBuffer[0]=13
    BalBuffer[60]=13
    BalBuffer[120]=13
    BalBuffer[180]=13
    BalBuffer[240]=13
    pause 2000
    debug "ready",13,10
    BalCount = 40
    HSEROUT ["40 ",STR BalBuffer\BalCount,13,10]
    debug   "40 ",STR BalBuffer\BalCount,13,10
    debug "full load "
    debug   STR BalBuffer,13,10
    HSEROUT ["full load ",STR BalBuffer,13,10]
    BalCount = 255
    HSEROUT ["255 ",STR BalBuffer\BalCount,13,10]
    HSEROUT [13,10]
    HSEROUT ["260"]
    BalCount = 260
    HSEROUT [STR BalBuffer\BalCount,13,10]
    Of course, since the macro only uses the low byte of R4 to index the array. That would also make it fail when using a constant >255.
    In any case, the "example" posted in the first place had a BYTE sized variable with a value of 40 and everything we've seen this far is that it should (and ideed does, for 18F at least) work. I think I compiled for 16F628 when I looked at the .lst yesterday.
    flotulopex,
    You're going to have to post code that we can just compile, assemble and program into a chip that shows the problem.
    SWITZERLAND (french speaking)
    Default HSEROUT using STR modifier - length parameter as variable not working
    flotulopex,
    Yup, I will do so asap.... Sorry, didn't have much time yesterday.
    Roger
    Charles replied:
    Yes, I believe it can be trusted with a variable. I've used this form to receive a variable number of characters based on a length parameter received immediately prior to the string:
    [wait($80),length,STR idstring\length]
    So officially it is valid syntax.
    For now, here a my two test programs with 16F690 and 18F1220.
    Surprisingly (to me), both accept the STR length as variable in the 3 ways I'm using it (HSEROUT, SEROUT2 and DEBUG).
    I'll go back to my current program and try again....
    Roger
  1. Determining variable length (number of digits) possible?
    Last Post: - 21st December 2020, 20:05
  2. Measuring a variable freq/length pulse and generating more pulses.
    Last Post: - 18th September 2014, 09:10
  3. hserout not working with parity
    Last Post: - 24th March 2010, 13:25
  4. HSERIN for variable length string
    Last Post: - 19th February 2010, 05:58
  5. Serin2 and STR Modifier
    By _Ian in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2005, 16:25
