CALL instruction not working
Results 1 to 6 of 6
    Jun 2007
    Mansfield, UK
    Default Re: CALL instruction not working
    I've spent a bit of time trying to get the debugger to work. I'm using an ICD3 but the dsPIC33E/PIC24E firmware seems to be quite buggy when using it as a debugger.
    It turns out that there was a bug in my custom compiler that was setting __SP_init and __SPLIM_init to 0. The PIC was correctly erroring because of a stack overflow.
    I've fixed the bug and it's all working now!
    @pedja089
    The main flash and auxiliary flash are both in the same flash space with the auxiliary section starting at 0x7FC000.
    The PC accesses both areas as if they are just 1 big area of flash so PC 0 would always be the start of the main flash.
    For the hardware, I'm using a custom PCB with the PIC24EP512GP806, an ENC28J60 with an RJ45 socket and a bunch of headers.
    It's currently plugged into a breadboard which gives me 2 LEDs that I've been using to "debug" the code
    I've uploaded a picture of the board if you're interested
    Sep 2009
    I assume that you had PIC18 connected with external flash.
    I totally missed your first sentence in first post. Sorry about that.
  1. 12F510 CALL subroutine problem ...
    By LakisFM1 in forum mel PIC BASIC Pro
    Last Post: - 15th November 2011, 09:21
  2. how to establish data call ??
    By hjahshan in forum GSM
    Last Post: - 14th April 2011, 22:28
  3. PWM instruction not working as I expect
    By peu in forum mel PIC BASIC Pro
    Last Post: - 20th January 2006, 19:39
  4. Replies: 3
    Last Post: - 15th December 2005, 07:31
  5. Missed call
    By Lotondo in forum GSM
    Last Post: - 29th September 2005, 15:39
